Best way to model guitar signal?
mistapitts
Post by mistapitts »
What is the best way to model a guitar signal? Currently I'm using a +/-1V 800Hz sine wave in Multisim, and I'm currently battling op-amp clipping in a clean boost I designed. Is the voltage too high?
The circuit is supposed to be able to boost the signal over 20db but I'm saturating the amp at about 10.
Crowella
Been thanked: 16 times
Post by Crowella »
Try using 100mV/0.1V first. :) 1V is rather high.
mistapitts
Thanks :D I figured I was just driving it too hard. Is that 100mV peak-to-peak or amplitude?
Crowella
Post by Crowella »
Apologies. Amplitude. :)
mistapitts
Awesome! Thank you.
grrrunge
Completed builds: Loads!
Has thanked: 50 times
Been thanked: 203 times
Post by grrrunge »
The highest output passive pickup i have, is a Dimarzio X2N, with an output of 510 mV. I always use that for "worst case" testing ;)
Simulating that case, i usually run simulations at +/-500mV.
Crowella
Post by Crowella »
I should have mentioned that it is naturally going to be different throughout a course of a note. The attack will most definitely be in the high range, sometimes even approaching 1V amplitude.
If I could find it, there was a nice way to simulate a guitar pickup in LTSpice using a transformer and/or inductor. For all intents and purposes though, a simple supply will suffice but just be aware it is by no means comprehensive but very suitable for simulations.
poiureza
Has thanked: 15 times
Been thanked: 9 times
Post by poiureza »
I recently tested the bridge HB on 3 guitars with a scope.
"Normal" strumming gets rarely above 0.2V amplitude.
If you bang on the strings like a chimpanze, the attack is about 0.5V amplitude but goes down to 0.1-0.2V amplitude after only a swing or two.
That's not music, that's pick attack noise.
I build all my circuit models with 0.1V amplitude and then I check what happens when I raise amplitude.
As for including pup characteristics in the model, there's a good read here.
The voltages I mentioned would obviously be after this circuit snippet.
The snippet is not really necessary IMO unless you build something without input buffer or very low input impedance (some fuzz', some wah's ...).
clintrubber
Has thanked: 16 times
Been thanked: 5 times
Post by clintrubber »
Once tested a passive bass, single coil, directly connected to a scope.
The sun was shining, the breakfast was good, the coffee strong, the pick heavy,
so the initial peak on the scope no less than 4V(peak), it might even have been 10V(peak).
Will this distort ? Sure, for instance it's totally incompatible with the a 9V supply of the first stompbox.
But you'll actually WANT that peaks like this are clipped/limited, no use in reproducing these.
And they'll be so short that the distortion is unnoticable.
Bye
