Bloody Little Bastard ll solid stage power amp
- rcustoms
This is an audio amplifier, simple but very stable and with good characteristics.
we can do it , with a few components and especially is very cheap to assemble( intermediate to advanced level ).
Another important aspect is that the same circuit can be configured with various wattages and mono or stereo modes, Ideal for fitting with our preamps projects.
- rcustoms
now see some check points and made the bobbin for zobel network
- rcustoms
- rcustoms
- rcustoms
- rcustoms
- rcustoms
like i said we can accommodate the pcb to made a 200w,400w mono or stereo versions stay tuned for this schematics and layouts
- grrrunge
Given the choice of emitter resistor values in the power stage, my guess is around 100mAtip142 wrote:Hi very interesting,only one question ,how much is estimated be the quiescent current across R16-R17?
- rcustoms
i replace the amp stage completely on a Laney HA200 combo amp,the original one blow and burn the factory pcb ,the cheapest solution in 200w stereo mode was this amp,i dont remember exactly but i think cost me around us 40 dls (without main transformer )i use the original preamp stage and the original transformer.
- rcustoms
layout for other modes
- blackbunny
Thanks for sharing the details of this amplifier with us rcustoms
This is just what I need to fix a scorched Laney R4B bass combo amp I have here. It has the usual shorted SMD diodes, transistors and resistors that I see in blown Laney bass amps, and I really don't want to try and rebuild that PCB, so I will give your BLB II circuit a try.
I owe you some beers!
- rcustoms
jaja someday my friendblackbunny wrote:Thanks for sharing the details of this amplifier with us rcustoms
for me is a pleasure to contribute with fsb.
many people do not appreciate the time taken to draw the graphics and share with everyone
- phatt
What happens when you short the speaker terminals?
I can't see any overload protection which means instant death to power transistors if/when output shorts out.
Unavoidable when using 6.5 phono plugs for speaker connections.
Phil.
Phil.
- rcustoms
hi phil asap i upload this speaker protection i work in the graphicsphatt wrote:What happens when you short the speaker terminals?
Phil.
- rcustoms
if you or anyone have designs ,schematics or something to mod this amp ,please welcomercustoms wrote:hi phil asap i upload this speaker protection i work in the graphicsphatt wrote:What happens when you short the speaker terminals?
Phil.
- sinner
- Has thanked: 1031 times
- Been thanked: 909 times
Small value, high wattage resistor across switched jack terminals?
- rcustoms
For me sound good, when I upload the speaker protection will be done. This amp coming from many brands like Sansui electronics and many others. I really don't know who's the first one to launch this design but is very common and cheapsinner wrote:Small value, high wattage resistor across switched jack terminals?
- tip142
grrrunge wrote:Given the choice of emitter resistor values in the power stage, my guess is around 100mAtip142 wrote:Hi very interesting,only one question ,how much is estimated be the quiescent current across R16-R17?
- sinner
To be honest I know nothing about solid state amp "physic laws"
Which is shame as I need some know how right now
But this is a simple method used in valve amp world
I can't see it "sounding" at all. It just faking load without speaker connected. It's removed from the path when speaker jack is plugged
