Stupidly Awesome Buffer  [documentation]
jeepe
Completed builds: I might be at level 2, so to speak..
not totally green, but that's all :)
my "level" is about building a big muff... medium complexity :)
I'll never build a DS-2, for example :)
even though I'm a layman to electronics
I'll never build anything without seeing the actual schematics too...
my all time favorite: Fuzz FAce
it is an always ongoing project..
I want to end up strumming some strings at the end of the day, whatever the sound
I'm so sad that this beautiful culture (and freedom movement) is totally ephemeral
Has thanked: 568 times
Been thanked: 21 times
Post by jeepe »
[quote="Manfred"]Hi Jeepe, you meant in that way?
exactly !!! thank you so very much !!! :) :)
you know what?
I was, after some 5-10 times of going at it and getting stuck, right now coming back to Supidly Awesome Buffer, cause
our fellow-forumer, Iforgot posted at tagboardeffects, under IvIark's buffer post http://tagboardeffects.blogspot.com/201 ... ffers.html that he had been using that vero for some time and he was
never really satisfied with it, and so he was about to try Stupidly Awesome Buffer, and mentioned that he even made a vero of it, and posted this link... as of Aug 2015...
AND here I was, again, after so many times :)
I was always tempted by this circuit, but since I have NOT made any buffer yet, I was also tempted by simplicity... (of Jack Orman's)
but then, thanks to Iforgot, I would, again and again, get back here, to the sophisticated, and beautifully performing Stupidly Awesome Buffer :)
but since I need two (to mix a bass guitar with a stereo "AUX" in, in a practice headphone amp, CMoy, you know), I'd have to draw the vero, and it's not only becoming complex, but also annoying, cause I know that 1 or 2 sections needn't to be duplicated... (around the +IN and the VCC+ legs)...
but how will I know that it works well?
or how will I know why it doesn't if it doesn't? :)
so, as I came here, again, I just saw this schematic, and right away I knew what that was :) :)
and then I realize that it's posted there only lately, oh, and even because I asked :) :)
THANKS so much!!!
also for the explanatory indication of modification :) (!! :))
and I hope that anybody will find it who's into building a buffer....
AND THEN :) :) a strip layout? (???)
with PDFs?? :) and PCB style photo illustrations???
you're simply generous :)
and extremely elegant :)
BUT, I'm trying to view this NOT from my personal aspect only, but from that of the community of DIY-musicians, who can not design circuits, but only build them...
and from Soulsonic's aspect, too... (hi! it is a privilege to have you in this part of the conversation ! :))
his work is not extended, both as a DUAL BUFFER, and in time, as a Buffer which is an active project even in the 2020s :)
anyhow, thanks to the both of you,
as well as thanks to Iforgot, who gave it a try seeking a better one than that simple Jack Orman "building block" :)
pedal building, tracing and sharing is such a beautiful freedom movement... If only it could be viewed as a future heritage, but it really is ephemeral, as it seems
jeepe
Post by jeepe »
soulsonic wrote:
I've built several different splitters over the years, and I would usually use 3 buffers: One like this circuit at the input and then splitting into two or more, one for each output. Having the buffer at the input lets you split to many buffered outputs without any additional loading on the input. I also did a few that had isolation transformers on one output to break hum loops that would frequently happen when using multiple amps.
thank you for sharing the sophisticated splitting concept!
sounds absolutely logical even to me!
and I'm happy that anyone wanting to build a very high quality DUAL BUFFER / splitter (I'm repeating these terms for google's bots) can find it right here, from the OP :)
thank you!
soulsonic wrote: I think I posted a schematic for this somewhere here already?
I couldn't find it... but this could be my fault (I couldn't find a "search _this_user_'s posts" link)
and of course, if you posted it again, it would be great, just for completeness' sake :)
(I am always taken aback by the fragile ephemerality of BASS and guitar culture in DIY circles... I mean, many of the websites don't even have SSL, picture links are broken, not to mention that parts have died out in the mean time, so it looks like it is not gonna make it to the 2030s, for example,
but luckily, freestompboxes.org is updated to today's standards, and to have those "drawings" of yours here, could be great)
AndrewGallios
Post by AndrewGallios »
hi
i want to ask about the R6-1k output resistor
does it have to be 100 ohm for low output impedance or the 1k its fine?
bmxguitarsbmx
Has thanked: 657 times
Been thanked: 203 times
Post by bmxguitarsbmx »
AndrewGallios wrote: 05 Mar 2021, 10:56 hi
Either is probably fine.
You could totally overthink this and calculate the output resistor for the power supply and the maximum output current of the op-amp. But, since this buffer doesn't have input or output protection, I wouldn't be bothered. (Input protection from being driven while buffer is not powered. Output protection from the discharge of C3 when powered off)
george giblet
Has thanked: 180 times
Been thanked: 272 times
Post by george giblet »
The resistor is there to stop oscillation with a capacitive load, 1k will work 100% of the time.
AndrewGallios
Hi I have a question if someone knows
What values in the parts should be changed to get a little bit of gain in this buffer? Just a touch more from unity gain
Cybercow
Been thanked: 28 times
Post by Cybercow »
Should be as simple as adding some resistance between the output of the opamp and the negative input of that same opamp. Try a 20K or 25K trimpot there and see what you get sound wise as the trimpot is turned with a signal going thru it.
mauman
Has thanked: 266 times
Been thanked: 144 times
Post by mauman »
With a non-inverting op amp, you'll also need a resistor R10 to the reference voltage (junction of R3/R4). And a cap in line (C6) will roll off the gain to zero <edit: unity> at DC, which is good practice. For a gain of 2 (+6 dB), make R9 = R10, and as you increase R9, the gain goes up. For a gain of 1.5 (+3.5 dB), make R9 half the value of R10, and as you decrease R9, the gain goes down. I'd suggest R10 = 10k, and C6 = 4.7 uF or 10 uF. Make R9 = 4.7k for a little over +3 dB, or 10k for +6 dB.
Buffer with gain
Buffer with gain
Cybercow
Post by Cybercow »
What mauman states is a better proposition for increasing the gain on this buffer circuit. Providing a reference to pin #2 helps stabilize the circuit by keeping the audio signal at or near a zero reference. Without it, as I postulated in a previous comment, the opamp can end up with a DC offset and the audio signal will be off-balance from a zero reference point.
m4268588
Post by m4268588 »
I don't understand necessity of C6.
Connecting C6 to Vref instead of GND results in low noise. And you are using the FET input device OP-Amp.
Is C6 inevitable?
mauman
Post by mauman »
m4268588 wrote: 17 Oct 2022, 03:13 I don't understand necessity of C6.
Is C6 inevitable?
It will work without C6, but this blocking capacitor rolls off the gain to unity at DC. The value is large enough so it doesn't affect audio frequencies. The goal is to reduce the effect of any input offset voltage in the op amp, which can be more than 10 mV in a TL071.
m4268588
Post by m4268588 »
I got it
