Hi! I have a bunch of pedals, all of them are true bypass, except for the crybaby that´s hardwired bypass. The problem I have is that I need a buffer in my effects chain, with all the pedals off I notice a loss of high end, istead of buying or building another pedal/buffer, I was wondering if I can use the input buffer of the Crybaby as an "always on" buffer. Here´s the schematic:
I'll have to add a cap between the end of the buffer and the 68k input resistor, make that cap the output of the buffer, and put the switch conection after that cap. But my question is if the Crybaby input buffer good for this or it´s not a good buffer for my effects chain? Thanks in advance!
