Ibanez - GE-300 Power Equalizer  [schematic]
HoggYBhoY
Has thanked: 16 times
Been thanked: 7 times
Post by HoggYBhoY »
the diode at the lED says 28 or 2B
I need more pictures of the wiring, can you do them for me?
I see no values on the sliders, they may be on the other side of the body. If you can unscrew them and take few pictures - that would be great
I got the main board drawn (layout), and partial schematic done, I need the picts/info above to finish it up
HoggYBhoY
Post by HoggYBhoY »
Thanks so much man its really appreciated!!
here are the pics the battery clips off to the left.
some of the screws that hold the sliders in place are stripped so
I cant get them off maybe someone else will be able to check.
HoggYBhoY
Post by HoggYBhoY »
the power jack connects to a battery clip adaptor that I made which then attaches to the pedal battery clips
Do you ever sleep?
Shame with the sliders :(
You have a little preview on my Facebook page
Thanks for the pics. This is what I needed
HoggYBhoY
Post by HoggYBhoY »
yeh ive completely stripped one screw trying :(
haha ill be going to bed soon working tomorrow.
I've got some OPA2134PA burr brown op amps here and I was going to replace the originals
as they did distort a bit with the boost up full so ill be changing these aslo
HoggYBhoY
Post by HoggYBhoY »
Another pic
tube-exorcist
Has thanked: 173 times
Been thanked: 67 times
Post by tube-exorcist »
sinner wrote:You will have the schematic tomorrow
I'm on it
So far no schematic yet.... but here is a chance for another (broken) one:
https://www.ebay.com/itm/Vintage-Japane ... 3cfaa1b572
Wont happen before Friday. It's holiday break at schools here and my kid stealing all my attention
I can post the layout easy to trace from. It's community AG, you will have your chance to help out
HoggYBhoY
Post by HoggYBhoY »
I'm on it
Yeh I might have to buy that just incase the broken bit
Is the big hybrid thing !
HoggYBhoY
Post by HoggYBhoY »
Sinner your a star thanks so much !
So I can now use this to find the fault
Where do I start ??
sorry for being a noob! Lol
ppluis0
Has thanked: 121 times
Been thanked: 278 times
Post by ppluis0 »
HoggYBhoY wrote:Yeh I might have to buy that just incase the broken bit
The "big thing" that appears in the previous images is nothing else than a 0.27uF polyester capacitor... 8)
HoggYBhoY
Post by HoggYBhoY »
One of the guys had said it was a hybrid
And not easily replaceable if it is that part
That is broken , I was gonna buy that broken
One on eBay for parts incase I needed it
Some one else has bid on it already GRRR! :horsey: :slap: :slap:
tube-exorcist
Repair advice:
Remove TR801, IC801 and IC802.
Replace TR801 with a new one (can be any japanese small-signal NPN-transistor)
Replace IC801 and IC802 with a new one and your unit should work again (If you don´t have a 1458 at hand, then use a 4558 instead).
HoggYBhoY
Post by HoggYBhoY »
Well i have 2 burr brown OPA2134PA op amps here
Which I was planning to put in the pedal anyway as the current
Op amps can distort a bit with the boost up full
I've got a few spare bc109b transistors here would these
Be a suitable replacement if so what hfe values would I need ?
tube-exorcist
HoggYBhoY wrote:Well i have 2 burr brown OPA2134PA op amps here
Take care about possible oscillation
HoggYBhoY wrote: Which I was planning to put in the pedal anyway as the current op amps can distort a bit with the boost up full
funny hearsay
HoggYBhoY wrote: I've got a few spare bc109b transistors here would these be a suitable replacement if so what hfe values would I need ?
Hfe doesn´t matter but the pinout is different so you must "adjust" the pins properly.
HoggYBhoY
Post by HoggYBhoY »
Yeh that's cool I know the pin out I used them in my
Wah pedal. Right if hfe doesn't matter I could use any npn
Tranny ? So I was wondering , Why would they have used that specific part ?
Sorry if that's a stupid question
Promised schematic
Just the component names but should be enough
It's late, I'm going to bed. I will update the schemo with values sometimes around the weekend
Updated schematic on the next page
ppluis0
Post by ppluis0 »
HoggYBhoY wrote: One of the guys had said it was a hybrid
Don't worry about that component since isn't any sort of hybrid or "obscure" custom part...it's nothing more and nothing else that an inexpensive capacitor... 8)
@HoggYBhoY
I need pictures or value confirmation of following parts
- R803 (10k?)
- R806 (1k?)
- R809 (150R?)
- 813 (360R?)
