Behringer - BEQ700 Bass Graphic Equalizer [schematic]
- modman
- a d m i n
- Has thanked: 4287 times
- Been thanked: 2008 times
BEQ700_MANUAL_ENG_Rev_A.pdf- Behringer - BEQ700 Bass Graphic Equalizer manual
- (339.31 KiB) Downloaded 163 times
BEQ700_SCHEMATICS_REV_B.pdf- Behringer - BEQ700 Bass Graphic Equalizer schematic
- (426.74 KiB) Downloaded 383 times
- NickS
Using a simple (non-Spice) calculation:
Of course, tolerances will affect this but it's interesting that the "120Hz" filter should be that far out when they go to the trouble to specify a 92 nF cap for the "800 Hz" (calc 746 Hz). It would be interesting to see the curves.
Code: Select all
Nominal Calculated
freq freq
50 49
120 153
400 394
500 533
800 746
4.5k 4823
10k 10526
- Andy2No
What was your calculation method, out of interest?NickS wrote:Using a simple (non-Spice) calculation:Of course, tolerances will affect this but it's interesting that the "120Hz" filter should be that far out when they go to the trouble to specify a 92 nF cap for the "800 Hz" (calc 746 Hz). It would be interesting to see the curves.Code: Select all
Nominal Calculated freq freq 50 49 120 153 400 394 500 533 800 746 4.5k 4823 10k 10526
Here are some curves for mine, taken with an Android app called Spectrum Analyze, via a Behringer UCA202 USB audio interface fed with a white noise sample. The green line was live; the red line is remembered peaks.
As you can see, at full cut on all the sliders, it's all over the place. The best thing you can say is that with all sliders in the centre, it's pretty level.
It's hard to see much detail at low frequencies, with this method, so I wouldn't read too much into the apparent bass response. That's not really the issue.
The file names explain the conditions they were taken under.
The first two are with the EQ sliders all the way down, with Level full up in the first one, then centred in the second.
The next one has all EQ sliders full up except the last/top one, which is full down:
Then all sliders full (if I've labelled that right - maybe not) - not sure where the level was: Then all centred: Doing one at a time might be more instructive, but you get the idea. The app and the audio device are both very affordable.
- NickS
OK, I note that it's not 92 nF, it's 82 nF which brings the calculated frequency to 790 Hz. Not sure where I got that from, nor the values that gave me 153 Hz; the values on the Rev B schematic there work out to 125.NickS wrote:Using a simple (non-Spice) calculation:
Today I used the gyrator calculator at http://www.muzique.com/lab/gyrator.htm. I thought I used that last time.
Code: Select all
Nominal Calculated
freq freq
50 49
120 153X 125
400 394
500 533
800 746X 790
4.5k 4823
10k 10526
