Hi ya fellas...
my build is freaky quiet ...really
right the layout is key...
totally agree and the pcb layout posted by
sinisa should work fine...just that error
audioguy pointed out.
Nice one
sinisa...thanks!
Gets some good J201's too.
Some updates:
1)use 100k trimpots for Jfet bias adjustments
2)If bass presence is a bit too much tweak tone stack resistor to a larger value e.g 56K, 100K ....
You can reduce Bass pot to 500k as I Meg is wee bit too much...imo.
3)A 27k ~ 47k resistor on the Gain Pot to ground to keep it going even if Gain pot gets turned off... sorry my mistake here.
I use 1M for gain.
4)Use 35v to 50v spec electro's and try this circuit on 18v
5)Use a 50k for presence pot with a 10K after presence cap to ground. U do not need a large value uF for this ....use 0.01uf and less to taste.
6) U can subsitute the expansive silver mica's used for 470pf with other types..i use those box type.
Ravi C.
