Enjoy!
There's an old Ampeg tone control that is very similar to the Rt66. I can't remember the amp's model #, you'll have to scrounge. I suspect the '66 tone control may be derived from that, but I wouldn't know.soulsonic wrote:Is that supposed to be a Baxandall tone control setup? If so, why isn't the connection to the volume control taken from the wiper of the Treble control as is usually seen?
I like EF86 tubes, but it's hard to find decent ones any more. Alot of them tend to have microphonic issues. I have a couple nice-looking Amperex ones, I scrounged out of an old tape recorder, but I haven't had a chance to try them out yet - that's why I would like to tinker with a circuit like this one.
The EF86 is a high gain tube that has a very rich, chimey distortion. This arrangement is found on the early Vox AC30/4 and AC15's (and is part of the reason they are so collectible). They [EF86] are prone to be microphonic, tube failure and this design was dropped by Vox as a direct result of. They switched to a ECC83 (12AX7) soon after but the design was very clean and guitarists missed the breakup of the EF86 design so they eventually implemented the top boost design (actually a Gibson amp design) to get some of that original breakup back.AL wrote:Just out of curiosity - why couldn't you build that with a single 12AX7 (instead of the EF86) and use a shared cathode and shared plate arrangement? Or is that going to put you in a MAZ/Ghia realm?
AL
