jonnygreentrees wrote:is the mosfet the DSG thing? I oriented it according to the schematic, will it cause any damage if I just flip it round to try it?
The Mosfet won't work properly if you flip it round, you need to make sure that the D,S, and G terminals are oriented correctly, do you have a Digital Multimeter you can use to measure the voltages?, if so, then use it to measure the voltages on the D,S, and G terminals, it sounds to me like the Mosfet isn't being biased correctly........
Also, check to make sure you have made any necessary breaks in the copper tracks in the correct places, and have a good look at the soldering with a strong magnifying glass to check to make sure you haven't made any inadvertent solder-bridges......
