Bazzrite
Nocentelli
Has thanked: 1115 times
Been thanked: 939 times
Post by Nocentelli »
I got tired of bread-boarding elaborate circuits for hours and having them not work, so i threw this together in a hurry knowing it would do something, and I was pleased with the resulting sounds:
The mix pot pans between stock bazz fuss at minimum, through a varied palette of graunchy out-of-phase fuzzy sounds complete with weird filtery/phase-shifty decay, and when turned fully up you get a reasonably sustaining high gain fuzz. It's got good clean-up with the guitar's volume too, though this is much better if you plug the guitar straight in (i.e. no buffer in front of the Bazzrite).
I tried 3mm red LEDs first, and got a strong sub-octave on the initial attack of the note (oddly this was strongest, and only really prominent at the 7th fret) but it decays a bit too fast and is somewhat erratic actually be a feature - It also turns chords into a mangled mess so I didn't bother pursuing it. Might be worth putting on a switch, though.
Ripdivot
Been thanked: 78 times
Post by Ripdivot »
Interesting, I might give this a try just to hear the out of phase sounds in the middle portion of the mix pot. Often these simple circuits can be a lot of fun. Maybe it would be cool to try a dual ganged pot in series with the diodes so you could blend in how much you like. Another option might be to add a cap in series with the diodes to tweak the frequency response of the clipping. Just thinking out loud. :hmmm:
Nocentelli
Ripdivot wrote:Interesting, I might give this a try just to hear the out of phase sounds in the middle portion of the mix pot.
You get a significant dip in output level as the pot moves towards the middle due to phase cancellation, but there is easily enough available to compensate by upping the volume control.
marmora
Completed builds: Distortion +
EA Tremolo
Weird Sound Generator
Mingrod
Honeytone speaker out mod
Line 6 DL4 and MM4 mods
Boss AC-2 clone
Sparkleboost
BSIAB II
Lofo Mofo
Jawari
Psychtar
CMOS Nyquist Aliaser
Paralooper
Punch-In-The-Face
Gargletron
Omni Drive
Blue Magic
Boss SG-1 clone
Parapedal
Feedback Looper
PEEPlug
ST-C Delay
Casio PT-100 bends
Riot Zone
HT8950A modulator
Blast Fed Disaster
Crushed Glass
Mac Oscilloscope
Gristleizer
Atari Punk Console
Dub Siren
UM3561 Siren
Bent Radio Shack Playtime Keyboard
Bent Animal Band Keyboard
Bent Barbie Karaoke
Rebote 2
PWM
Distortus Maximus
Woolly Mammoth
Phase 45
Dr Boogie
Femtoverb
Random Number Generator
Mayhem!
Uglyface
Bent Casio SA-40
Clari(not) Cubed
Black Toast
May Queen
Bent Speak and Read/Math
Thing Modulator
Geofex Low Fidelity/Noise/Telephone
Lovepedal Woodrow
Bazz Fuss
Bent Vtech Alphabet Desk
Bent Realistic Rap-Master
Noise Box (modded Lofomofo, Noise Ensemble, Dirty Sanchez)
Robobuddy
Post by marmora »
Nocentelli
Almost identical. I'd not seen that before, but I recognise user earthscum from DIYSB, seen to recall he posted a number of cool but fairly simple designs.
I wonder if the higher collector-resistor and mix pot values might help reduce the volume dip in the middle?
marmora
EA Tremolo
Mingrod
Boss AC-2 clone
Sparkleboost
BSIAB II
Lofo Mofo
Jawari
Psychtar
Paralooper
Punch-In-The-Face
Gargletron
Omni Drive
Blue Magic
Boss SG-1 clone
Parapedal
Feedback Looper
PEEPlug
ST-C Delay
Casio PT-100 bends
Riot Zone
HT8950A modulator
Blast Fed Disaster
Crushed Glass
Mac Oscilloscope
Gristleizer
Atari Punk Console
Dub Siren
UM3561 Siren
Bent Barbie Karaoke
Rebote 2
PWM
Distortus Maximus
Woolly Mammoth
Phase 45
Dr Boogie
Femtoverb
Mayhem!
Uglyface
Bent Casio SA-40
Clari(not) Cubed
Black Toast
May Queen
Thing Modulator
Lovepedal Woodrow
Bazz Fuss
Robobuddy
Post by marmora »
Nocentelli wrote:Almost identical. I'd not seen that before, but I recognise user earthscum from DIYSB, seen to recall he posted a number of cool but fairly simple designs.
I played with the design recently and I'm pretty sure there is still a volume dip. Still fun to play with though, don't want to discourage anyone from playing with this.
I also played around with the two 470k resistors that go to the collectors. Instead I used a 1M pot to vary the resistance and got even more sounds out of this simple, but neat, circuit.
I wish the original schematic image was still around. It was a wonderfully symmetric layout.
Cheers to you Nocentelli, please update us if you experiment more.
PS Where did Earthscum go? He did have some cool Escobedo style simple circuits.
FiveseveN
Has thanked: 196 times
Been thanked: 106 times
Post by FiveseveN »
marmora wrote:I wish the original schematic image was still around.
Here it is, if it's OK to post it here:
