MIDI Switcher for ZOOM MultiStomp (MS 50g and MS70-CDR,MS60B)
m10065
Been thanked: 24 times
Post by m10065 »
Hi I'm GSMCustomEffects
Japanese Circuit Engineer!
I made MIDI Switcher for ZOOM MultiStomp(MS 50g and MS70-CDR,MS60B)
myVine
https://vine.co/v/Od7Pnp0AaqV
using Arduino and USBHostShield
Schematic and SourceCode Here!!
this is my Blog in Japanese
SourceCode
http://garagestylemsc.blog.jp/archives/20654052.html
Schematic(Layout)
http://garagestylemsc.blog.jp/archives/20767328.html
this Switcher presetnumber10 is bypass
you can programchange 1~8!
enjoy!
zoomSW1
zoomSW1
tangalanga
Post by tangalanga »
Excellent! Thanks for your work and generosity!
m10065
Post by m10065 »
Reply Thank you.
It is the current case of the design.
Once you have completed drawings will also be published.
Function is as Vine
Thank you in the future!
m10065
Post by m10065 »
cross section
2mm!
m10065
Post by m10065 »
side view
Scheduled to take power and USBMIDI connector on this surface
Position of MIDI connector undecided
Exploring the current position
pamaz
Has thanked: 32 times
Post by pamaz »
I'm trying to understand and dowload the code form your website, but I'm having a few difficulties due to the japanese language ( and google translator is not helping that much!) .
Can you please point me to the correct link for downloading the code pls?
Paolo
apollomusicservice
Has thanked: 64 times
Been thanked: 819 times
Post by apollomusicservice »
pamaz wrote:I'm trying to understand and dowload the code form your website, but I'm having a few difficulties due to the japanese language ( and google translator is not helping that much!) .
Paolo
Try this
MIDIAB.zip
(1.85 KiB) Downloaded 306 times
m10065
Post by m10065 »
Thanks for Uploading!
m10065
Post by m10065 »
Long time no see
This time more of MIDI switcher I will introduce so was completed.
A mode
1,2,3,4
B mode
5,6,7,8
send ProgramChangeMIDI messege
left switch is mode change Switch!
The case is our original design
We were outsourced to sheet metal forming
andershenrik
Post by andershenrik »
:applause: Thank you ,this is interesting . I was not aware that the MS50 can be controlled by midi . Anybody know a link to the commands ?
m10065
Post by m10065 »
andershenrik wrote::applause: Thank you ,this is interesting . I was not aware that the MS50 can be controlled by midi . Anybody know a link to the commands ?
Thank you for questions
I think that it is not perhaps know
kaya112
Post by kaya112 »
In file included from E:\arduino-1.6.5\libraries\USB_Host_Shield_2.0-master/Usb.h:27:0,
from sketch_sep22d.ino:2:
E:\arduino-1.6.5\libraries\USB_Host_Shield_2.0-master/settings.h:139:176: fatal error: SPI.h: No such file or directory
#include <SPI.h> // Use the Arduino SPI library for the Arduino Due, RedBearLab nRF51822, Intel Galileo 1 & 2, Intel Edison or if the SPI library with transaction is available
compilation terminated
:scratch: :scratch:
divabanana
Post by divabanana »
I have a question regarding the powering of the Zoom MS-50G.
It looks like you are powering it via the USB bus from the USB host shield.
(In the MS-50G specs it says you can power it from USB so that's all good).
What I don't understand is the power adapter they recommend is 9v but USB bus power is only 5v.
I asked Zoom about this and they said that the required power is 9v and the device does not adjust voltage...
So how is the 5v from the USB bus enough when it requires 9v?
Can anybody shed any light?
Been thanked: 9 times
Post by 56335130 »
divabanana wrote:I have a question regarding the powering of the Zoom MS-50G.
same as g3.when use usb power ,the inside bump the 5v to 9v and let the analog chip works.
m10065
Post by m10065 »
Long time no see.
Since I was able new site thank you
http://diystompbox.html.xdomain.jp/index.html
m10065
Post by m10065 »
Long time no see.
I tried to control of the GT100
m10065
Post by m10065 »
Ben N
Has thanked: 167 times
Been thanked: 50 times
Post by Ben N »
Hey, m10065, sorry I'm late to the party--just got my MS-70CDR, and it's really my first digital pedal. Can you provide updated links for the code and schematic?
BTW, just around the same time as you, a fellow named Lawrence Doss came out with an Arduino based controller for MS. Are you familiar with it? Are there any important differences?
eggyfreestompbox2018
Post by eggyfreestompbox2018 »
Anybody can share the schematic link ?
The existing link can not open.
Thank You
JudgeMingus
Completed builds: JH-1 renovation with mods for crisper tone
Tuner/Mute box with loop reverser (for Gilmour 'seagulls' wah effect)
Si Fuzz Face clone
Rat clone
Tonepad Rebote 2.5 echo
Phase 90 clone
MXR noise gate clone
Runoffgroove Professor Tweed
Distortion+ clone
OD250 clone
Fuzz Central Liquid Drive
MXR DynaComp clone
Orange Squeezer clone
Demeter Compulator clone
Skreddy Lunar Module clone
Dual-output buffers (derived from AMZ Super Buffer)
Several more under way!
Has thanked: 39 times
Been thanked: 8 times
Post by JudgeMingus »
I would certainly also be interested in the schematic if it can be reposted!
