Maxon - PH-350 Rotary Phaser
- idy
- Completed builds: FFs, Octavias, TBMKIIIs, Buzzarounds/alikes, Axis Fuzz', CS Overdriver, BMPs, Black '65s, MOSFETODs, WiiO, RAH, Klons, AC30, DLS, TSs and many variants, Small Clones, UniVibes, E. Mistress, Mutron Env Filter, Ross/Dynacomps,, EA Trems, TremLunes, Katana Boosters, BYOC Tri Boosters, other boosters and buffers, PT2399 delays, SKRM based delays, Belton Brick Reverbs, 3band parametric EQ,
- Has thanked: 27 times
- Been thanked: 31 times
This one has escaped the forums and layout sites. Switchable 4/6/10 stages, the feedback control is minimum at noon, one direction adds fb out of phase, the other in.
gut shot here:
http://www.modezero.com/maxon-ph350.htm
gut shot here:
- Dirk_Hendrik
True. And I'd love to tackle this one.
But it's not going to happen without pictures of the trace sides of the boards.
- andrej
- my favorite amplifier: Vox AC30
- Completed builds: Zvex Woolly Mammoth
Boss DS-2 mod
Vox AC4
Crowther Hotcake (and own variations)
TS-808
Big Muff Russian
Big Muff IC
Superfuzz
Superfuzz
Big Muff
Mixer/Blend
various other stuff - Location: montenegro
- Has thanked: 6 times
- Been thanked: 51 times
- Contact:
How hard are these to find?
It's my holy grail of phasing, along with the Red Witch Moon Phase (also untraced).
- idy
One on Ebay for $220, one on Reverb for $300+...
- idy
without the back side mucho guess work amigo.
- modman
- a d m i n
- Has thanked: 4287 times
- Been thanked: 2008 times
http://www.thegearpage.net/board/index. ... or.254435/
Maybe check with our member Bucksears?
Please, attach pictures of guts to the thread. This way info gets collected and stays available for anyone wanting to work on this next week, next month, next year...
"The cause of the "vocal/wah" type sound of the PH350 comes from the fact that it uses photocouplers instead of FET's to create the phasing effect. Photocouplers are well known for their vocal-like audio quality, and they were used in all the original Mutron products as well as the original Univibe. Barely anyone designs around them anymore for several reasons - 1) They are expensive 2) They are hard to find 3) They are temperamental and have wide tolerance ranges so they generally must be matched for optimum sound quality. This is the reason the PH350 is somewhat expensive compared to other phasers."
http://www.maxonfx.com/article-better-guitar-2004
- Dirk_Hendrik
Looking at that photo I'm fairly sure I can draw up a schematic that is 98 or more percent correct. How?
By using the older brother:
http://dirk-hendrik.com/temp/ibanez_ph99.pdf
- idy
Thank you! Better than magic. The PH99 has the switchable stages and the +/- feedback.
- Dirk_Hendrik
- Fender3D
Just guesses...
from picture posted it looks like it uses the schematic posted by Dirk. (10K filter resistors are there, 24k compressor feedback res too, and many other values on board seem coincide with schematic)
with 2 more static stages and 2 moving stages.
I can't say about LFO (it may be on the lower PCB with controls), but 1 more vactrol won't need further circuitry....
- soulsonic
Sorry, I had taken these photos back in 2009 when I had worked on one of these to modify it for true bypass. Completely forgot about it.
I didn't take any photos of the board with the controls, sorry.
