peavey MX vtx series footswitch
hi mates.
i have this amp
http://assets.peavey.com/literature/man ... 343009.pdf
http://www.kijiji.ca/v-other-musical-in ... 1040475576
http://www.cavallimusica.com/chitarre/c ... eries.html
unfortunately i don't have the footswitch/remote switch, which is the only way to go from lead to clean(!)
so....
i've searched everywhere and i can find the schem for that footswitch
it has a 4 pin din unlike most peavey amps that have a 5 to 7 pin dins
is there anyone that could help??
thanks
Savvas
i have this amp
so....
thanks
Savvas
- karul
According to the schematic, the pins are
1 - REVERB GND
2 - REVERB
3 - CHANNEL GND
4 - CHANNEL
pins 1 and 2 are for the REVERB ON/OFF
pins 3 and 4 are for CHANNEL SWITCHING
1 - REVERB GND
2 - REVERB
3 - CHANNEL GND
4 - CHANNEL
peavey_mx_vtx.pdf- (1.04 MiB) Downloaded 177 times
huge thanks mate!
that was superfast!
i've already tried this by shorting the tips with aligator clips and it works!!!
thanks again!
that was superfast!
thanks again!
Hello,
I just made a plug in which I connected 1 + 2 & 3 + 4
There's no channel indicator as far as I know
Reverb is no longer working, if I take the plug out reverb is working again.
So got those pins right.
In what mode does the amp start with no plug clean channel / reverb on ?
Please advise.
Marc
Please advise.
Marc
- karul
what kind of switches you're using? latching or non-latching (momentary)? you need two separate latching switches. one for the reverb, one for channel switching. if you want state indicator, you'll need battery or power supply and some LED's and proper resistors.marc036 wrote:Hello,
Please advise.
Marc
- karul
I'm not very familiar with this amp. I recommend you to carefully read the manual.
It seems that the to use the Normal (clean) channel, you should connect 3 & 4. Try to leave 1 & 2 disconnected so the Reverb will be ON, all the time.
User manual for MX VTX Series:
https://www.manualslib.com/manual/62047 ... eries.html
