FET switching n00b here with a question.
Posted: 15 Jun 2008, 00:56
Hello!
I am trying to repair an Ibanez SD9 with a switching problem. I have built A LOT of pedals but I have never messed with FET switching. I'm attaching a schematic of the pedal. I replaced the switch thinking that was the problem and it was not. The pedal will switch if I touch the red/white wire to ground but I have to hold it on there for a second or two before it happens. Is it possible that a FET is just reacting too slow and needs to be replaced? The momentary switch is of course a really quick connect/disconnect so it's not doing the trick. If I desolder the red/white wire and touch it to the black wire on the other side of the switch for a second or two the pedal will switch on/off.
Ideas?
Ideas?
