Long time no posts. Had a lot on my back and a lot of projects to be done, so after a while, i've managed to finish this project that was on my mind for some time now.
It's a small full tube practice amp that uses 6N16B double triode as an output tube (submini) and a 6N16B / 6N17B double triode as a preamp tube.
The schematic is based on Marshall 18W and the power stage is made in a self-split configuration.
Controls are: 1 volume and 1 tone knob and one switch that will enable a single or parallel preamp stage
For the HV it uses a SMPS module.
Project documentation is available here: https://dl.dropboxusercontent.com/u/152 ... %20SFA.pdf
Also the PCBs will be available for buying (the fist batch is sold out - 30pcs, but i will prepare a 2nd run if someone is interested). PCBs can be pre-ordered (no payment ahead required) on this topic or by an e-mail at: gtudoran@gmail.com
You can also get in touch with me on my FB page: https://www.facebook.com/dextersworkshop.ro (all updates are posted there)
Here you have some renders of the amp and also some views of the PCB
Regards,
Gabriel Tudoran aka. DeXTeR
