EBRAddict
Posts: 31 Joined: 30 Dec 2014, 14:23
Has thanked: 14 times
Been thanked: 19 times
Post
by EBRAddict » 15 Aug 2015, 18:39
Spin FV-1 on the left
Official video
VIDEO
It says 100% handmade in the video... the builder must be a cyborg because every solder joint looked perfectly uniform. It's a great sounding pedal.
Posts: 4817 Joined: 19 Jun 2007, 16:57
Has thanked: 4287 times
Been thanked: 2008 times
Post
by modman » 15 Aug 2015, 19:27
Could you also share the trace side of the pcb? It's essential if somebody would want to trace it.
thanks!
Ice-9
Posts: 1086 Joined: 31 Mar 2009, 15:29
Has thanked: 134 times
Been thanked: 359 times
Post
by Ice-9 » 15 Aug 2015, 22:24
EBRAddict wrote: [
Image ]
that pcb has through hole plating , when soldered from the bottom the solder flows to the top , it will always look perfect
electrosonic
Posts: 130 Joined: 28 Nov 2008, 16:53
Has thanked: 27 times
Post
by electrosonic » 15 Aug 2015, 22:54
Check out the cool method of connecting the pcb and the enclosure (bottom right of pcb photo)
Andrew
EBRAddict
Post
by EBRAddict » 16 Aug 2015, 00:55
modman wrote: Could you also share the trace side of the pcb? It's essential if somebody would want to trace it.
thanks!
I didn't post it earlier because it has a waffle-weave finish and it is difficult to see the traces even with a mangifier. Taking a pic directly from on top shows almost nothing.
Since it is a FV-1 DSP chip I don't know how useful the rest of the circuit would be without the program. I saw a 4558 chip under the B50K.
I may pick up a FV-1 development kit, Spin quoted around $130 back in April.
teej212
Posts: 109 Joined: 03 Jun 2009, 00:24
Has thanked: 4 times
Been thanked: 8 times
Post
by teej212 » 16 Aug 2015, 11:52
This shouldn't be different from any of his other pedals in terms of hardware. Ice 9 traced out the tunnel worm so that schematic should be of interest to you. Not sure I remember seeing the ferrite beads though.
Jack Deville
Posts: 403 Joined: 02 Apr 2009, 06:21
Completed builds: too many. too many.
Has thanked: 1 time
Been thanked: 86 times
Post
by Jack Deville » 05 Sep 2015, 00:23
EBRAddict wrote: [
Image ]
Official video
VIDEO
Built by 100% live humans in my shop.
We just know how to build pedals.
Thanks for your interest. Took quite some time to design that pedal. Good luck.
Ice-9
Post
by Ice-9 » 05 Sep 2015, 20:59
Jack Deville wrote: EBRAddict wrote: [
Image ]
Official video
VIDEO
Very nice Mr. Deville, and a first in that size pedal
Jack Deville
Has thanked: 1 time
Post
by Jack Deville » 05 Sep 2015, 21:23
Ice-9 wrote: Jack Deville wrote: EBRAddict wrote: [
Image ]
Official video
VIDEO
Actually, a straight up first. Period.
Ice-9
Post
by Ice-9 » 05 Sep 2015, 21:47
Jack Deville wrote: Ice-9 wrote: Jack Deville wrote: EBRAddict wrote: [
Image ]
Official video
VIDEO
absolutely a first, and hand built gear at a price that is affordable, I doff my hat to you sir.
drbob1
Posts: 453 Joined: 21 Dec 2010, 20:30
Has thanked: 7 times
Been thanked: 40 times
Post
by drbob1 » 08 Sep 2015, 21:39
Your comment on my other thread about using two BBDs to produce a Shepard effect I'm assuming was research for this project, since the finished product is Spin vs BBDs? (I'm sure it's more cost effective this way). Do you mind revealing how many "voices" if I may put it this way the Shepard has?
roseblood11
Posts: 1880 Joined: 23 Aug 2008, 14:21
Has thanked: 359 times
Been thanked: 312 times
Post
by roseblood11 » 08 Sep 2015, 22:38
Most of the FV-1 based pedals really don't impress me, but this one sounds really good.
Jack Deville
Has thanked: 1 time
Post
by Jack Deville » 14 Sep 2015, 06:00
roseblood11 wrote: Most of the FV-1 based pedals really don't impress me, but this one sounds really good.
Most pedals don't impress me.
It's really all about the engineer.
Thanks again for noting my work. Best of luck on this one.
Also, schematic published is incorrect.
