two SE amps into PP ??
borislavgajic
Has thanked: 131 times
Been thanked: 277 times
Post by borislavgajic »
Is this possible???
I have 2 singleended EL84 amps ....is it possible to connect them in push pull configuration...(with phase iverter before it ,and with two (original ) output transformers connected together to bring out more power??? :scratch:
Is this possible to do?
http://www.aikenamps.com/SingleEnded.htm
JiM
Proco Rat
Hot Harmonics
Crackle Not OK
Has thanked: 69 times
Been thanked: 65 times
Post by JiM »
Stereo solid-state power amps can often be bridged (even if they already are push-pull), giving twice the power in one load of twice the impedance. Just inject the same signal inverted in one channel, wire the HP between both hot outputs, and tie ground outputs together.
I don't know if this is feasible with tube amps, would two independant output transformers, series-series connected work like one center-tapped ? On a schematic it seems OK, but in real life the magnetic flux will be separate :hmmm:
If it's safe, and without special PI trick, you'll obviously end up with a class-A push-pull amp with the sum of the power of the original amps. Exactly like your two separate amps, but in mono ...
If you're looking for more power, you'll have to change the bias for class-AB or B. But if you just need more presence, use some subtle stereo effect and place the amps far from each other.
borislavgajic
Thank You JiM !
:thumbsup
