Death by Audio - Fuzz War  [traced]
gena_p1
Has thanked: 23 times
Been thanked: 11 times
Post by gena_p1 »
are you sure about 680n ceramic caps? m'be they are standard 100n?
xampworshipx
Post by xampworshipx »
So after actually playing one of these, I can say with 100% certainty that I can make better pedals than this.
The volume knob literally does nothing.
The tone knob works from about 7 to 8:30 and then has no discernible affect on the sound.
Cheaply made garbage that does nothing.
Space Jm
Post by Space Jm »
Hello xampworshipx,
Did you try the original "Fuzz war" or a clone you did on your demo board ?
Because it could be very different, not sure the schematic is 100% accurate.
Together we stand, divided we fall
John Lyons
Been thanked: 30 times
Post by John Lyons »
Hmmm
The original one I had didn't work like that.
The tone control had a wide range with some
semi parametric sweep type sounds.
Big fuzz and a lot of different tones.
Not for the weak but that's implied.
waldganger
Post by waldganger »
Space Jm wrote:Hello xampworshipx,
i've been reading all... and it seems like everybody here has problems bulding it :hmmm: ... maybe the schem is the key...; i've not a single idea about tracing circuits (from the photos), eagle's neither... i cant help it. BUT, im sure i love this pedal badly; and i wanna build it...
does anyone succeed whit this pedal?... new verob. or schem?... it would be great !!!
ps. (i damn myself for my poorly knowledge :scratch: )
xampworshipx
I was referring to the real one. Tried it with a jcm800 and a les paul at a guitar shop near me. Was not stoked.
poodlebra
Post by poodlebra »
i bought in a bunch of 5089's so i could make this. got some for sale for any UK'ers who want to have a crack. ebay user: chakkaboom
good luck! i'd definitely breadboard first.
btw- i pulled my layout, as it seems that there are problems with it.
Brainbender
Completed builds: Fuzz Factory, Shin-ei Fuzz, Sixties Fuzzface, Fender Blender, Bazz Fuss, RAT, Tonebender, SFT, Blue Box, Super-fuzz, Big Muff (many versions), Mosrite Fuzzrite
Has thanked: 20 times
Post by Brainbender »
flood wrote:ok, here we go: here's the .sch and .brd files. Format is Eagle 5.0.
i'm not that good with PCB design, so please feel free to correct any mistakes in the layout (and be kind!).
don't know when i can actually get this up and running though, have moved back home recently and don't have materials or space to do this sort of thing right now.
has anyone tried this? is it verified? I see there's lots of 430k resistors, and reading all this i see that they should be 820k?
How can I export just traces in an Eagle? :scratch:
the_ungod
Been thanked: 7 times
Post by the_ungod »
Does anyone has a sucesfull build?
Is this schematic verified?
gigelmargel
Has thanked: 111 times
Been thanked: 23 times
Post by gigelmargel »
the_ungod wrote:Does anyone has a sucesfull build?
I've built it sometime ago, but it never worked as in the demos...too gated and too much noise...I ended trying to bias the transistors one-by-one, replacing all 100K/180K/430K resistors from the emitters/colectors with trimpots, but no luck at all.
I am very interrested about it, because the demos sounds very killer!
the_ungod
Post by the_ungod »
gigelmargel wrote: I am very interrested about it, because the demos sounds very killer!
Yes it does.... :shock:
celadine
Has thanked: 16 times
Been thanked: 19 times
Post by celadine »
I breadboarded it (a year ago or so) with all different transistors for kicks. Didn't excite me, it sounded like two Big Muffs 'stacked' together. Shrug. But it did work.
gigelmargel
celadine wrote:I breadboarded it (a year ago or so) with all different transistors for kicks. Didn't excite me, it sounded like two Big Muffs 'stacked' together. Shrug. But it did work.
do you have mnore details?
the_ungod
Post by the_ungod »
celadine
Post by celadine »
gigelmargel wrote:do you have mnore details?
What would you like to know about?
the_ungod
Post by the_ungod »
How to make it work!lol
gigelmargel
celadine wrote:What would you like to know about?
What transistors have you used and how you biased them (if you did that)...some voltages would be useful, but I think that you disassembled it.
Thank you!
celadine
Post by celadine »
I used a bunch of different junk transistors pulled from different stuff. All reversed. I used 390k resistors instead of the weird 430K, only because of laziness. Otherwise built according to Analog Guru's schematic. It might be good to use medium gain transistors in this, instead of super high gain types, cause the ones I used were all probably 100-300 hfe. Because of the horrible, cross-your-fingers biasing of this pedal, its a miracle if any sound comes out of it. Good luck! :block:
gigelmargel
celadine wrote:I used a bunch of different junk transistors pulled from different stuff. All reversed. I used 390k resistors instead of the weird 430K, only because of laziness. Otherwise built according to Analog Guru's schematic. It might be good to use medium gain transistors in this, instead of super high gain types, cause the ones I used were all probably 100-300 hfe. Because of the horrible, cross-your-fingers biasing of this pedal, its a miracle if any sound comes out of it. Good luck! :block:
Thank you very much celadine!
