Ibanez - FL-9 Flanger [schematic]
- analogguru
Here some guts of the Ibanez FL9 Flanger:
and here is the factory schematic:
http://www.mojotronics.com/images/FL9.pdf
- FL9(2).pdf
- Ibanez - FL-9 Flanger schematic
- (271.19 KiB) Downloaded 606 times
- puppiesonacid
cool, thanks ag. the FL-9 is one of my favorite flangers aside from the mxr and the FOXROX TZF. It also can get really good chorus sounds as well.
I just got my ibanez FL-9 made in Japan yesterday. Is it worth changing the LED to a brighter 3mm red one? Or should i leave it as it is?
- Greenmachine
- my favorite amplifier: Fender Blackface Deluxe Reverb
- Completed builds: Electra Distortion
Roger Mayer Octavia
Klon Centaur (Bajaman/Soulsonic)
DOD 440 Envelope Filter
MXR Phase 90
DOD FET Preamp
Dallas Arbiter Fuzz Face
Soulsonic Hunny Bunny Overdrive
BYOC Analog Delay
Craig Anderton Headphone Amp
Anderton Mini Amp
Bajaman Real Tube Overdrive
Fender Deluxe 5E3 with Tone Stack Mod.
Fender Princeton 5F2-a
Keen Neovibe
Aquapuss Delay
Anderton AMS-100 Guitar Synth (abandoned)
DOD 280 Compressor
Weird Sound Generator
Beavis Audio Noisy Cricket
80's Rat
ROG Thor
Big Muff
Green Ringer
Shin-Ei Fuzz
MXR Dynacomp
COT50
Really Cheap Compressor - Location: Jersey City, NJ
- Has thanked: 87 times
- Been thanked: 17 times
- Contact:
Whatever floats your boat.
- Dirk_Hendrik
What exactly does the "made in Japan"mean. All FL9's were made in Japan. Unless you have a reissue which means it would be more worthwile mentioning that.
Better lower the value of the zener in series with the LED.
- borislavgajic
- Opamp Operator
- Has thanked: 131 times
- Been thanked: 277 times
http://www.box.net/shared/md9ahno2fo
nice man from Novi Sad took this guts......so trace side is here now
which one is better sounding...this, or fl301(with MN3007)?
enjoy
Boris
enjoy
Boris
- Dirk_Hendrik
- borislavgajic
- Opamp Operator
Sure do!....that was there for long time!!!! thank You mister DirkDirk_Hendrik wrote:might help too!
so what do you people prefer MN3007 or MN3207 flangers ..?
stupid question, but please reply
Boris
- borislavgajic
- Opamp Operator
http://pdf1.alldatasheet.com/datasheet- ... C1583.html
how to replace this with common transistors?
is it possible?
thanks
Boris
is it possible?
thanks
Boris
- lolbou
These are built-in "difference amplifier". You can replace them with two identical NPNs connected as shown I believe, though you may need to get the specs close enough. Maybe a good result could be expected from an opamp actually?
In a thread here, Dirk mentions that the FL5 is a dead-on copy, I'll take some gut shots to post in the other thread and check for any replacement part...
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
- Dirk_Hendrik
jep.borislavgajic wrote:http://pdf1.alldatasheet.com/datasheet- ... C1583.html
is it possible?
thanks
Boris
Just take 2 transistors from the same production line. Ibanez quit using those in the AD99 already.
- lolbou
It seems that two 2SC1815s are making the job in the FL-5.lolbou wrote:and check for any replacement part...
ps: guts posted in the FL-5 thread...
- Redhouse
Maybe?:borislavgajic wrote:http://pdf1.alldatasheet.com/datasheet- ... C1583.html
is it possible?
thanks
Boris
LM394
MAT02
MAT12
- Dirk_Hendrik
replace C132 and C135 (47uF/ 6.3volts) first
- bucksears
Resurrecting this one with an interesting finding:
I just got an FL-301DX (9V) on Monday (2nd one I've owned). It has a really noisy 'swoosh' (like air blowing), but the flanging works fine, so I opened it up to have a look. It also runs the MN3207. After taking hi-res shots of the solder side, I noticed the layout is VERY similar (about 80-85%) to the FL9. I'd bet good money that the only major difference in the FL9 is the addition of the Delay knob.
My vintage/MIJ FL9 has some kind of grounding issue where the LED stays slightly on when bypassed, causing any true-bypass pedal attached to it to pop when switched on/off.
I'm recreating the PCBs in Illustrator (should fit in a 125-B), so I'll have a better idea of them in a week or two. Ideally, I'd like to build new ones minus the buffer/switching and compare them back to back.
- Dirk_Hendrik
Your problem description gives me the suggestion there is a resistance between the GND connection of the power supply and the GND on the PCB. This causes the circuit GND to float compared to the power supply GND and causes the output to have a DC offset. Hence the pops on other pedals.
