Want to make Judder
kissy
Post by kissy »
HI.
I want to make judder that have only three toggle switch.
But i cant find circuit and layout.
kissy
Post by kissy »
Sorry.i mistake.
But this circuit is in need of three toggle switch.
Please tell me i will do!
HELP ME !
Has thanked: 218 times
Been thanked: 857 times
Perhaps take some time to enlighten others what a judder is? Some links etc. Seems to be a PT2399 delay but then, what is so special about this variation of the same circuit that's in the PT's datasheet.
kissy
Post by kissy »
Thanks for replying.
sorry, i cant find movie only Japanese
Judder is very strange stomp.
its based on looper,delay,glitch and modulation.
it have three toggle switches and momently 9PDT footswitches.
footswitches do three role that have been selected by first toggle switches.
first switches have stutter,judder and layer mode.
[stutter mode]
it is the same as mute mode.
[judder mode when the rate is at a min]
while foot switch are pushed,this mode continue to play a sound that inputted when pushed footswitches without inputted sound.
[judder mode when the rate is at a max]
while foot switch are pushed,continue to play a sound that sliced.
(while to push footswitches, judder mode play effect sound without input sound.)
[layer mode]
it is standard delay.
second toggle switch is bypass.
because Judder is use momently footswitch, input signal always through buffer.
bypass switch use not to through buffer, it to be direct input to output.
last toggle switch is dirt.
You can extend the sound can input it . However , the sound will contain a lot of noise .
this is judder of all.
please tell me more.
