XO Stereo Clone Theory issues
Fender3D
Has thanked: 120 times
Been thanked: 150 times
Post by Fender3D »
yes [smilie=a_goodjob.gif]
pins 2 and 6 got clock
kiltro
Post by kiltro »
Shouldnt I have -15v on pin1?
https://datasheet.octopart.com/MN3007-P ... 103261.pdf
Also, why there is also this one around? Vdd and GND are swaped
Schermata 2022-10-14 alle 10.34.42.png (43.34 KiB) Viewed 558 times
Fender3D
Post by Fender3D »
MN30xx chips have pin 1 voltage more positive than pin 5, whereas MN32xx chip have pin 1 voltage more negative than pin 5.
What you use as GND is inifluent, as long as pin 1 is more positive than pin 5 for MN30xx
kiltro
Post by kiltro »
Ok thanks
But shouldnt it work on 15V?
Fender3D
Post by Fender3D »
on this datasheet https://pdf1.alldatasheet.com/datasheet ... N3007.html you can see diagrams traced with supply voltage up (down?) to -5V.
In my personal experience, I couldn't get MN3007 working very well below 12V, surely really bad under 9V.
kiltro
Post by kiltro »
Fender3D wrote: 16 Oct 2022, 12:38 In my personal experience, I couldn't get MN3007 working very well below 12V, surely really bad under 9V.
Well I've -8.8v on vdd and -8.3v on vgg
Maybe I'm missing something but I dont see any charge pump on my pcb (there is one on some other clone theory schematic). :scratch:
Fender3D
Post by Fender3D »
Clone theory and small clone work both @9V.
kiltro
Post by kiltro »
Fender3D wrote: 17 Oct 2022, 10:56 Clone theory and small clone work both @9V.
Yeah you are right.
So, is there any other way to check for power supply stability (beside a DMM with min/max, that I dont have) ?
Thanks for your help
Fender3D
Post by Fender3D »
You can try and check tracks continuity, while stressing PCB...
And/or check supply voltage, stressing and whacking PCB
kiltro
Post by kiltro »
So, while I was trying to reverse engineering the schematic I've found that the rotary switch is broken...
It's an Alpha SR1712F-0203-15K0A-N9-N, apparently they are also in Micro Q-Trons
Problem is I'm only finding it at smallbear electronics and at synthcube.com, but since I'm in Italy the shipping would be EXPANSIVE
Someone know where to find these in Europe?
Fender3D
Post by Fender3D »
kiltro wrote: 25 Oct 2022, 20:49 since I'm in Italy
Facevamo prima a parlarci in italiano :lol:
kiltro
Post by kiltro »
Fender3D wrote: 26 Oct 2022, 10:23
Lol
