Two effects in one box switching question
- marmora
- Completed builds: Distortion +
EA Tremolo
Weird Sound Generator
Mingrod
Honeytone speaker out mod
Line 6 DL4 and MM4 mods
Boss AC-2 clone
Sparkleboost
BSIAB II
Lofo Mofo
Jawari
Psychtar
CMOS Nyquist Aliaser
Paralooper
Punch-In-The-Face
Gargletron
Omni Drive
Blue Magic
Boss SG-1 clone
Parapedal
Feedback Looper
PEEPlug
ST-C Delay
Casio PT-100 bends
Riot Zone
HT8950A modulator
Blast Fed Disaster
Crushed Glass
Mac Oscilloscope
Gristleizer
Atari Punk Console
Dub Siren
UM3561 Siren
Bent Radio Shack Playtime Keyboard
Bent Animal Band Keyboard
Bent Barbie Karaoke
Rebote 2
PWM
Distortus Maximus
Woolly Mammoth
Phase 45
Dr Boogie
Femtoverb
Random Number Generator
Mayhem!
Uglyface
Bent Casio SA-40
Clari(not) Cubed
Black Toast
May Queen
Bent Speak and Read/Math
Thing Modulator
Geofex Low Fidelity/Noise/Telephone
Lovepedal Woodrow
Bazz Fuss
Bent Vtech Alphabet Desk
Bent Realistic Rap-Master
Noise Box (modded Lofomofo, Noise Ensemble, Dirty Sanchez)
Robobuddy - Location: Chicago
- Has thanked: 1 time
- Been thanked: 4 times
- Contact:
Here's what I'm looking to do: Build two effects into one box with a little extra flexibility. For simplicity's sake, let's call each one effect A and effect B. I plan to have regular bypass switching, but then I want to have a toggle switch that allows me to choose between these options:
Only effect A
Effect A into effect B
Only effect B
If anyone can lead me to a layout of how to do this, that would be incredible!
Only effect A
Only effect B
- JiM
Proco Rat
Hot Harmonics
Crackle Not OK
- Has thanked: 69 times
- Been thanked: 65 times
- Contact:
If you don't care about true bypass of each effect when the other one is used, you could use a special DPDT on-on-on switch on the output of each effect. These switches are a bit hard to find, in the center position they connect the center lug of each pole to the opposite lug.
And then use traditionnal bypassing for the whole box.
If you do want individual true-bypass, the simple and effective way is to use standard bypass for each effect (as if they where in two separate boxes) and two footswitches. Keep them close enough to stomp on both at the same time, and you can do all the combinations : bypass, fx A, fx B, both.
That's what i did for a TubeDriver and a Phase 45 in the same box, and it works like a charm, with two Millenium bypasses.
You could even put an FX loop on the link between the two effects, have a look at the "Proco Juggernaut" thread.
Code: Select all
/ | \ left center right
[o=o o] [o=o o] [o o=o] -> Fx A output Fx B input input jack/Fx A input
[o=o o] [o o=o] [o o=o] -> Fx B input output jack Fx B output
Fx A both Fx B
- marmora
EA Tremolo
Mingrod
Boss AC-2 clone
Sparkleboost
BSIAB II
Lofo Mofo
Jawari
Psychtar
Paralooper
Punch-In-The-Face
Gargletron
Omni Drive
Blue Magic
Boss SG-1 clone
Parapedal
Feedback Looper
PEEPlug
ST-C Delay
Casio PT-100 bends
Riot Zone
HT8950A modulator
Blast Fed Disaster
Crushed Glass
Mac Oscilloscope
Gristleizer
Atari Punk Console
Dub Siren
UM3561 Siren
Bent Barbie Karaoke
Rebote 2
PWM
Distortus Maximus
Woolly Mammoth
Phase 45
Dr Boogie
Femtoverb
Mayhem!
Uglyface
Bent Casio SA-40
Clari(not) Cubed
Black Toast
May Queen
Thing Modulator
Lovepedal Woodrow
Bazz Fuss
- Contact:
Thanks for the replies. What about adding a tri-color LED? One to let me know I've got effect A, A&B or B on. I've got a couple of 3 position 3PDT switches (although I think they're on-off-on)
