Ahoy gals and guys,
I was comparing the schamatics of varius electric mistress versions the other day, and among other things I notics that v2 has a 220nF cap across the range knob that does not show up in later versions :
http://www.metzgerralf.de/elekt/stomp/m ... ematic.gif
There is also a 33k and a 1uF tantalum cap that have been removed in later versions. The total resistance between the range pot and filter matrix switch / ground are also different. I assume that especially the first difference might be quite important. Could anybody shed some light on how the first two changes are affecting the sound and function of the circuit?
Thanks a lot in advance!!
Electric Mistress range cap
Btw, first post here (I had the impression that i had posted in the past as well, but i was wrong as it seems) so since I have been reading your forum for quite some time, I have to say a big thank you for all your contributions and for sharing your knowledge
