Ordering single sided PCB on line
casey73
Post by casey73 »
I'd like to order some simple, single layer PBCs via one of the on-line PCB services. I've looked around and haven't found any that make a simple single sided board. The ones I've found have a minimum of 2 layers. Anyone aware of anyone who produces old fashioned single layer PCBs?
Ice-9
Has thanked: 134 times
Been thanked: 359 times
Post by Ice-9 »
Anyone who makes 2 layer boards should automatically make a single layer board if you send the file/gerbers of a single layer board. You may have to select a 2 layer board in their system but you will get board you require.
The people I usually use are PCBcart and they list single layer on the website, other people like OSHpark for small orders will work by selecting 2 layer. I doubt any price difference will be available if you can find a single layer service.
Has thanked: 218 times
Been thanked: 857 times
Wuerth in Germany does em.
And they cost more than double sided. While single sided does not offer any added value over double sided while double sided, even if everything is routed on a single layer, offeres considerable value over single sided.
cdeschenes
Has thanked: 34 times
Been thanked: 19 times
Post by cdeschenes »
casey73 wrote:I'd like to order some simple, single layer PBCs via one of the on-line PCB services. I've looked around and haven't found any that make a simple single sided board. The ones I've found have a minimum of 2 layers. Anyone aware of anyone who produces old fashioned single layer PCBs?
Why not take this opportunity to learn how to etch for yourself. Its really not that hard at all and you might even have most of the needed tools at home already. I have a tutorial on how I etch my PCBs if you like to check it out.
http://music.codydeschenes.com/?page_id=1388
Cody
dmgfx
Post by dmgfx »
All Electronics and Electronics Goldmine has single sided copper pcbs All sizes.
newly
Post by newly »
where is your geography location?
