there was no bad attitude on my part, but I'm sure my words were misinterpreted.
The reason for no replies is because this is a guitar pedals forum. Guitar pedals are normally simple and basic electronic circuits, most of of the forum members will be guitarists completely new to electronics trying to do some pedals for fun. So it's not that people don't want to help, it's because most can't really help because they don't have the knowledge to do so.
Thats what I meant in saying that the reasons for no help was not because I was not posting a picture but was actually "deeper than that"
For the rest of forum members, the ones that are really knowledgeable 2 things happen, or they are bombard a lot with all the less experienced members asking for help or they are respectfully working on their own projects. Point is obviously they don't have the time for all the needs around here, it's understandable.
That's why I didn't get 1 reply at all in a thread about a missing component, can only be a capacitor or a diode, in the most basic circuit there is for a guitar pedal, a transistor booster.
Because of this I still feel that a picture of the Out B jack wiring from a working unit would be and still is the best option, if any member of this forum as one of this units, and is helpful enough to take the 4 screws and take 2 to 3 pics with the phone. It takes 1 minute, and Im pretty sure in so many people in this forum there will be someone that has this pedal in their collection.
That is much easier than expecting and experienced forum member to chime in, having to understand a complex digital circuit from pictures without schematics,
beware this is not an overdrive project, the circuit is not an overdrive.
Ice-9 wrote:
I have just had a look at your picture on the other thread you have pointed too and the quality of picture is not very good
Sorry, But you're wrong the pictures are very good.
The pictures are there to show the spot of the missing component and they perfectly represent that.
I explained everything in the thread.
Ice-9 wrote:I have never seen a circuit that acetone does not remove flux
As I told in the thread, I dont know if this is flux or whatever it is, but Acetone doesn't remove it.
Ice-9 wrote:it looks like the damage is from trying to remove that stuff
No it's not, did you read the thread?
As I explained the damage is from a burned component, probably it was a diode and probably it was because of an higher voltage or wrong polarity used. My doubt is if there was a capacitor also parallel to that diode
Ice-9 wrote:so unless you have the skills to trace that pedal and fill in the blancs from the damage then I would give up on that one. or find a schematic already published.
There's no schematics already published for this Revision of the Fatboost.
Yes I have the skills to trace the circuit, told that in the relevant thread, what I still dont know is how to take that gunk/cement out without damaging traces on the PCB.
But even if I couldn't trace it there a way that anyone could really fix it, even a newbie, it would be if a forum member with the same pedal posted a picture of the guts of his working pedal.
Or following your advise, by putting my pedals pictures then " a lot of intelligent people here can make something of the pictures you take and post", but no one really posted. And even you that suggested this option looked to my basic/boost pedal circuit, 1 component missing and you say "I would give up on that one" LOLOL really? thats not really coherent.
As you see I did this thread in the "Requests" section of the forum,
it's a place that is dedicated to ask something like a "Schematic or guts shots for Repair"
And I will still would like to ask this,
Please if theres a forum member that owns an Yamaha DSC-20M Chorus pedal it would be really helpful if you could take some pics of the OutB jack wiring.
Thanks you so much
If someone has or encounters a Schematic for this pedal, that would be great also.
