MEC WARWICK 3 BAND EQ RF ISSUE  [schematic]
mistermikev
my favorite amplifier: deville 4x10
Completed builds: -modded big muff (russian) w 6way rotary selecting clipping dioes/emitter lift/true bypass/new pots.
-modded ts8 with diodes, 4558chip, 10k/100ohm resistors
-byoc analog chorus-built a two true bypass loop/order switch
-tube crusher = tube screamer + orange squeezer
-booster
-nurse quacky
etc
Post by mistermikev »
so... thanks to all parties above for schems. this is on my 'must try' list and since I've had some time on my hands this weekend... I did a layout and will wire one up sooner or later. Just wanted to share.
Have checked it 3x (not saying I'm incapable of mistakes!).
My layout is setup to mount the pcb on a push pull. Extra pads around the pot for parallel resistors to bring a 250k to the 100k value.
https://www.dropbox.com/s/0kp86oepx1ug1 ... p.png?dl=0
I have all the parts on the board populated... so all the real work is done... now I just have to get it working.
