Zorg Effects - Love Philter [documentation]
This is my take on a classic variable state filter with optocouplers!
I added a few cool features:
- A possibility to control it with an envelope follower, an expression pedal or a control voltage. (You can actually use the 3 together, but it's a bit weird how it reacts!)
- A mix button, which allows for cool blending, phaser-like sounds.
Using the CV in with a good LFO, you can use it as a LFO-wha, Tremolo or 2 stage phaser.
It has a few imperfections though:
- It does not go into self oscillations (but almsot, or if you power it with a bad switching alim.)
- Using CV+Exp pedal+Env reacts strangely.
- depending on the optocouplers, you may have to trim the exp pedal stage so that the pedal is usable as a wha wha (Sometimes it can sweep the entire audio range, and that's a bit too much for a wha wha!)
- Optocouplers are not ROHS... I shall redesign this filter with OTAs in the next months!
This leads to the presentation of the pedal on my website
Here's a demo with a Barry White like voice speaking smoothly in your ears:
Here's the schematic: And the mounting instructions full of guts:
French: http://zorgeffects.com/images/Manuels/L ... ons_Fr.pdf
English: http://zorgeffects.com/images/Manuels/L ... ns_Eng.pdf
Any comment/question welcome!
I've just publishd a short document for schematic explanations:
In French: http://www.zorgeffects.com/images/Manue ... ata_Fr.pdf
In English: http://www.zorgeffects.com/images/Manue ... ta_Eng.pdf
Hi I'm Thomas
I bought the full kit on zorgeffects.com and I think I did something wrong somehow but in the end the pedal reacts strangely: when I'm in LowPassFilter mode and with the presets of the video "fixed filter" and "auto wah", I can only get a sound only if I play very hard on my strings and it stops right after, like if there was some kind of gate...
I was thinking it was maybe the TL072IP is dead. Would it possibly be a reason? Must it be the reason? Can it be something else?
Thank you.
Thank you.
That would be interesting, I try to keep that in mind if I see a friend that has a cock fight on his pedal board!roseblood11 wrote:Would be interesting to see a side-by-side comparison with the EHX Cock Fight.
Hi
Built my love filter and love it!
To use it fully, i'd now like to be able to switch between envelope filter mode and wah mode with exp pedal.
How could I add a switch in the love filter to bypass the exp pedal input?
I tested with a 3PDT but my wiring must be wrong because I only achieved to have exp input in one position and no sound at all in the other (very limited electronic knowledge here
You can try something the other way around: just use your switch to toggle the Sensitivity pot middle leg to the ground. It'll be like if your sens pot is at 0, removing the envelope, but the expression pedal will still work... Then if you toggle the Sens pot back, the expression pedal would still work on it, but you'll just need to push back the expression pedal where you need...
That's just perfect! Even better than that I wanted to achieve in the first place!Gabe_ wrote: ↑26 Sep 2021, 12:06 You can try something the other way around: just use your switch to toggle the Sensitivity pot middle leg to the ground. It'll be like if your sens pot is at 0, removing the envelope, but the expression pedal will still work... Then if you toggle the Sens pot back, the expression pedal would still work on it, but you'll just need to push back the expression pedal where you need...
Many thanks for the quick reply, good tip, and your great work with the Zorg effects pedals!
Best.
