Here are the features:
- full tube construction with 12AX7 tube (the unit is delivered with TAD tube)
- high voltage using SMPS (is not a starved plate design)
- based on Alembic F2B preamp (with some improvements: separate gain/volume controls and an optional output buffer - unit is delivered without the optional output buffer).
- wall-wart included 12V @ 1A / DC (center negative)
This unit is the last prototype before i will lunch it into a small run and can be delivered immediately.
