Zener design question
I'm questioning the value of using a zener as the polarity insurance diode in a pedal, as is done with any design I've seen that has the zener as the way to "regulate" the voltage to X volts (esp. with charge pumps). I see this with the cathode on the power input and the anode to ground. There is no current-limiting resistor to enable the zener to actually control the voltage - because (I'm guessing) you don't want the voltage drop when the input voltage is close to (or below) the zener voltage (like battery power). But without that CLR the zener *cannot* dump any material voltage to ground - for example, if your external power supply supplies 10.8V with *any* appreciable current capacity then the zener *cannot* keep up, and the input voltage will be the voltage. Where this can really hurt is any circuit with a charge pump. Every charge pump I've looked up that is in regular use in pedals has 12V (or less) as the MAX voltage. If your 12V regulator is on the high side of tolerance (I've seen many 7812 regulators output 12.9V) then your zener will probably fail and/or the charge pump will get HOT because it is being operated out of range.
Is this analysis accurate? What am I missing? Is there a good solution?
Thanks,
Michael
Thanks,
Michael
- mictester
Just for the sake of amusement, I got a small pile of various manufacturer's 7812 and 78L12 regulators. I fed them from my bench supply at 16V, loaded the output with an LED in series with a 2k2 resistor (the first value that came to hand, and measured the output voltages with an accurately calibrated Solartron desk multimeter.
Out of 40 tests (I got bored) none gave an output of more than 12.13V. None were lower than 11.97V.
I don't know where you got your "12.9V" 7812s from, but I suggest that you return them as faulty or you get your meter recalibrated!
A Zener is a really poor way to give over-voltage and polarity protection. I use an isolated input socket feeding a bridge rectifier input, so idiots can't plug in a "reversed" supply. The output of the bridge goes into a 7812 (or whatever other voltage I require, with the body tab screwed to the effect case, and the screw used as the star point for earthing inside the box. If some idiot connects up an AC supply, there won't be any damage, but there will be a loud hum at the output!
- deltafred
- Opamp Operator
This ^mictester wrote:get your meter recalibrated!
Hobby multimeters give you an indication not a measurement. If you want to measure things you need to get them calibrated to a traceable standard, and then get them recalibrated regularly.
On 2 of mine if the battery voltage starts to fall then the readings go up. It caught me out the first time it happened.
Sorry, that was a typo - should've been 12.1V. I'd correct the original post but that would make your reply seem bizarre. I'm certain that my meter is fine, though probably not to the standard of your desk meter.
As to the zener for polarity question - that is part of what I was asking. More than that, though, is the question about charge pumps and max voltage sensitivity. It seems to me that if you're going to run a charge pump then you should use a real regulator as you mention, or just stick to batteries.
Thanks for the education - I'm quite experienced in tube amps but new to pedals.
What triggered this question was I built a "Catch-22" from Grind (Timmy-ish circuit, but with a charge pump). I have an old DOD supply (form the very early 90's) that gives over 11V and it was getting the charge pump chip quite hot. It has a 9.1V zener for polarity protection but that was doing nothing. I'm not even sure if the zener is still good. So it seems to me that I have to be careful w/r/t the input voltage. Time for a new power supply.
- mictester
You might not need a new PSU - just get a 7809 regulator IC. It'll give (almost) exactly 9V out for anything over about 11V in. Remember to bypass the regulator very close to the pins (I usually put 100n from input to ground and output to ground). I've even been known to use surface-mounted capacitors and solder them to the legs of the regulator IC where they emerge from the body of the chip!
- Dirk_Hendrik
I take may hat off. I would have gotten bored after 2 or 3 already.mictester wrote: Out of 40 tests (I got bored) none gave an output of more than 12.13V. None were lower than 11.97V.
- mictester
I just lashed up a test rig on a plug-in breadboard, and plugged in some of the 7812s (and 78L12s) that I had in stock. Each test took just a couple of seconds - plug in, note voltage, unplug, next! I did it because I'd never really considered the accuracy of the 3-terminal regulators - I just slap them into a circuit and assume that they're pretty accurate, especially since the absolute voltage doesn't usually matter: +/- 0.5V (or even more) doesn't really matter.
- Dirk_Hendrik
Which makes me think.
I dont care too much about the exact outpu voltage of that regulator if it's within say +/- 10% of the stated voltage. I would care however, if that output voltage would fluctuate. Because that's the situation in which one cannot base voltages like biases on that supply voltage.
- mictester
Just for my amusement, (and my education) I tried a random sample of various 12V regulators (several different manufacturers) fed from a 16V supply, and tried varying the load on the output to see how much the output voltage changed. I'm happy to report that the 10 7812 devices I tried all stayed within 20mV over the output current range of 30mA to 900mA. The biggest differences between devices of various brands was the output noise - usually well filtered by the bypass capacitors. Other than that, they all performed pretty much the same.
I also tried varying the input voltage, but as long as I was over the specified operational threshold, the output Voltage remained constant.
- Ice-9
Buy or build one of these 'High Precision Voltage Reference circuit' to check and set your DMM , you can buy or build one for less that £4 using an AD584 IC
http://www.ebay.co.uk/itm/Brand-New-AD5 ... SwcOFWajuO
