I've seen a DIY project with an active BMP tone control which seems pretty cool as you save one gain stage because it's placed in the feedback loop.
So there is no need for a recovery stage respectively a buffer.
Guess this could be very interesting for a view pedal builders..
I like the BMP tonestack a lot but would like to add the "Body" control of the AMZ Presence Control to alter the mids.
Not sure about the values,what a pity I'm not into spice..
Just imagine what a killer tone control this could be, simple, efficient and nearly none tone sucking!
Here's the schematic: Can I ditch the yellow circled resistors?
Does replacing the red circled resistor with a pot, let's say 50 to100k, work the same way like the body control?
How do I have to change the other values to get a similar response to the presence tone control?
Thanks in advance
