I have an original 1978-1980 grey MXR NoiseGate that hasnt worked for years. I finally got around to repairing it & had some issues. Then I found the thread on this forum about the MXR Noise Gate, folks seeking the schematic, doing replica builds, mods, and/or troubleshooting problems. In that thread, several people were having the exact same issue as I'm having now.
Long story short, is I got the pedal working & it is gating. But I'm having the exact same problem as others had that is discussed on pages 3 & 4 of that thread. It's where when the gate is engaged it's filtering down or squishing the incoming guitar signal & it's at 1/2 the normal volume & a bit distorted. When the gate is off, the guitar input signal is full level & proper.
It should be noted that I changed a few components on my stock pedal to those discussed in that thread. It wasn't working right before I changed the components & it started gating after I did. So the folks on that thread were onto something (Does that mean the original MXR design has some flaws in it? Because the pedal never did work 100% correctly since the day I bought it back in the late '70s as a teenage rock guitarist).
Anyways, here the components I changed:
1M --> 1.8K (between JFet gate & 150K)
22K --> 680 (between 5.1V Zener diode & Vcc)
680 --> 4.7K (between -IN of U1 or U1a going to gnd)
1uf --> 2.2uf (same as the 4.7K)
Also, it appears that all the opamps, transistor, & JFet are all working, and I measured all the resistors & caps, which appear to be good and at expected values. So my guess is some resistors and/or capacitors are off in selected value & need to change to fix the problem. But I'm not sure what & where values should be changed.
I was wondering what the guys on that past thread did to come up with a solution that fixed the issue?
If that info is not available or forgotten about, then starting fresh from the beginning on this thread is fine too
