I bought a cheap cheap Joyo Tremolo pedal.
It sounds good but i would like to make it more versatile.
For now on, sources are saying the Wave Form of the trem is Square Triangle. (something like this:
)So it let you ear a sweet tremolo.
But i would like to be able to obtain something more agressives, with more cutting edges like a Square wave (
)I saw on youtube some videos (not really enough tutorial friendly for me to understand it all) where the guy is adding a potentiometer to replace resistor R11, and listenning to what he says, turning down the value of this R11 get the Wave Form to something Square as i needed. (sources: and )
So, for testing purposes, as i am a lazy guy, i just soldered a cable to both legs of the R11 to short circuit it kinda (Two resistors in parallel with one having quite no resistance at all so)
It is still not agressive enought at all. (for example, one easy to listen sound i would like to get is the one you can ear on Greenday - Boulevard Of Broken Dreams song)
So if any of you knew any mods for this cheap and cool pedal, could you maybe share a CLEAR tutorial or something to help me out? Any mods, but the Agressive Square wave, bug tremolo, is the one i really am looking forward first of all ^^
(Maybe short-circuit the R11 and change to Intensity Knob For a higher value? 50k originally. Or any possibility to solder some resistors to the knob to increase its value? no idea)
Thanks a lot Electronic Wizards!
