Pearl - PH-44 ( Phaser )  [schematic]
borislavgajic
Has thanked: 131 times
Been thanked: 277 times
Post by borislavgajic »
http://www5b.biglobe.ne.jp/~houshu/synth/Ph44core.gif
Does enyone have something more on this???
please
Bernardduur
Has thanked: 89 times
Been thanked: 645 times
Post by Bernardduur »
I have one now open and tracing........ man, big pedal with a lot of connections :)
The Rotagilla
Post by The Rotagilla »
I've only got the schematic for the PH-03, sorry. :cry:
borislavgajic
some guts ??? ...................thanks :thumbsup
kierc
my favorite amplifier: Vox Cambridge 30 R Twin
Completed builds: Clyde McCoy Wah with Whipple+Red Fasel inductor switch, Fuzz Face with own layout
Post by kierc »
There's one on eBay right now (couple of hours left though! @ £49 atm)
http://cgi.ebay.co.uk/RARE-80s-Pearl-Ph ... dZViewItem
Just thought I'd post it!
Bernardduur
Schematic (put in parts as it is a HUGE one :))
PSU
Audio path
Phase stages
Parameters
Switching
The huge thing on the right on the parameters schematic is a MC14007 IC with the pinnumbers..... didn't have on in my software. Everything in this unit is fed with the V+2 (12V) but the LEDs are fed with V+1 (18V). Speed ramps up and down when the speed button is pressed.
Part marked "switch" in "Switching" schematic connects to "Sw" in "Audio path" schematic
The Rotagilla
Awesome, thank you!
borislavgajic
thanks...... it is big!!!
unbeliever
Post by unbeliever »
Thanks. :thumbsup
Has thanked: 218 times
Been thanked: 857 times
Bernard,
Excellent work! Those buggers are bitches to trace.
borislavgajic
can somebody please repost those images and schemes???
thanks
boris
Bernardduur
I'll upload em
Check
mictester
Has thanked: 32 times
Been thanked: 825 times
Post by mictester »
Bernardduur wrote:I'll upload em
Check
Excellent!
Now that's a different way of doing a phase stage! If you select the transistors (or use an array on an IC), you can eliminate differences between stages. I'm going to have a play with that way of doing things. Thanks for posting your tracing! :thumbsup
borislavgajic
Check
:hug: :D
borislav
floris
Has thanked: 230 times
Been thanked: 72 times
Post by floris »
Check
I know it has been a long time...
But can someone upload again the original, and hopefully higher resolution than currently on PhotoBucket, schematic picts of this PH44?
I'm having trouble reading the components.
Bernardduur
Bernardduur
floris
Post by floris »
Thank you Bernardduur for the high res schematics!
https://reverb.com/item/4410953-pearl-phaser-ph-44
My new car was cheaper than this!
JMX
Post by JMX »
never mind...
