Half 12AU7 doesnt work, maybe.
Faber
Post by Faber »
Hi all!
Is it possible that only half of a tube doenst work?
The tube is a new JJ ECC82 running at 12V. The heaters are connected in series, pin 9 unconnected. Both sides light up.
I was building my circuit and with the first triode (1-2-3) as first gain stage was all ok, with the signal coming out and all.
When I connected the second triode (6-7-8) as second gain stage nothing happened.
I rechecked wiring and all but to be sure I've rebuild the circuit using the second triode as first gain stage. Nothing.
It's still on breadboard and if I move the jumper wires from 6-7-8 and connect them to 1-2-3 the gain stage is working.
For more info:
plateR: 100k
catR: 680R
GridLeakR: 1M
Thanks all.
Faber
Post by Faber »
Edit: if I disconnect pin8 while always using 6-7-8 triode, signal goes through, but not amplified. If I connect pin 8 it's muted.
