MN3205 vs V3205; why won't my delay work
- Bernardduur
Hi all!
I have this old Pearl AD-08 that uses a MN3205 and a MN3102. It broke like a month ago without any real issues.
Upon inspection all seemed to function except for my MN3205. I scope the signal up to the input of the BBD where it disappears.
I tried it with a V3205 without succes. The BIAS setting makes no difference. No signal comes from the BBD.
I tried it with a BL3208 (because I have some laying around) and that works.
Do I need to buy a MN3205? Is there any difference between a MN3205 and a V3205?
Attached is the schematic
- Dirk_Hendrik
I used V3205's without a problem in the past. I couiild be your V3205 is broken. BBD's are very vulnerable to ESD.
And.. the signal flow in your schems contines to amaze me!
- Bernardduur
Thanks!Siro78 wrote:I know that v3205 work with limited power supply like 7V.
Try limiting V+2 at 7V if it start to work.
Bye
I tried limiting it by adding back the 100R resistor on the ground of the adapter jack. I removed that one because it worked on a 'standard' battery for years and that battery gave me more then 9V.
Afterwards it worked like this for approx 6 years
I've added that 100R resistor back but still the unit would not function. No sounds from the delay line. I now tried it with 2 more v3205's to make sure I wasn't killing them.
In a last resort I replaced all power ELCO's and replaced all ELCO's around the BBD. They were replaced around 6 years ago when I was busy modding this pedal (TB, less noise, etc).
AND YES, IT WORKS AGAIN. Also the 'old' v3205's I still had in my parts bin work. I'm pretty happy
