What's wrecking all my op-amps?
Electric-Gecko
Post by Electric-Gecko »
I have been attempting to make effects pedals for my electric bass for about a year and a half now. I have only once soldered one onto a PCB, which was a tube-screamer which didn't work. Other than that, I have only bread-boarded them, which seem to have worked the minority of the time. I use schematics from the internet, although I often make slight modifications.
I sometimes notice my op-amps becoming non-functional. Sometimes, I wouldn't know if the problem was the op-amp or the way that I built my circuit. But recently, I tested a circuit with 3 different dual op-amps. I confirmed that my long-suspectedly broken TL072 was indeed broken, and that it worked with 2 other op-amps. But then I think one of those broke later that day. I also built tried to breadboard another pedal with a new TL074 (which used all 4 op-amps), but it didn't work; just fuzzy noise. So I suspect that it somehow broke during construction or something.
I figure that many people just look at schematics, and put them onto a PCB exactly as it appears. But I tend to reuse them on a breadboard a few times, to try different schematics, and test how they work.
So end of story, what could cause op-amps to break? What should I do to prevent this?
I have found in my searches some things about input voltage, that it must stay between the supply voltages. Here's a way to use diodes to prevent the positive input from going significantly outside that range;
But some schematics use single power supplies, so the ground pin of the audio jacks are connected to the op-amp negative power input. Wouldn't this cause the input voltage to go lower than the negative power? Don't audio signals oscillate between positive and negative voltages?
I also wonder if an op-amp could be wrecked if there's no feedback path (from the output to negative/inverting input). Would the op-amp destroy itself by attempting infinite gain? What if I have unused sections of a multi-op-amp chip? Would the unused op-amps break when powered on?
NickS
Post by NickS »
I have found in my searches some things about input voltage, that it must stay between the supply voltages. ...
Yes, so in this case you would use a blocking capacitor and bias the input halfway between the voltage rails.
Though it should not destroy itself (the TL07x are supposed to be short-circuit proof), open-circuit might result in oscillation so it would be good practice to ground the unused + inputs (if using balanced supply, else to your Vref) and connect the output to the - input.
Other thoughts:
- Be conservative with the voltage rails - limit them to +/- 12v.
- Although the TL07x series have some static protection built in, ensure that you are taking static precautions.
- To avoid heat damage from soldering use IC sockets.
