mid boost with boost only ?
Hi!
Just like to know if it's possible to use a standard circuit for mid boost/cut to have it to boost only ?
Like a circuit with a gyrator to a op amp +\- inputs for boost / cut.
Anyway, I just want it to boost......
Hope U understand what I'm looking for.
Thanx
Peder
Thanx
Peder
- deltafred
- Opamp Operator
Use a pot of half the value that the cut/boost is and pad it with the same value resistor so you cannot go into the cut portion of the range.
(Hope that makes sense!)
- EddieTavares
