Ehx lob-1 loud pop
I have a linear power boost that pops when turned on and off in the fx loop.
I've did some research and this is what I have tried.
I have tried a 2m2 resister on the input and output jacks from tip to ground.
I then tried a wire from the negative end of the led to the pot to ground it to the chassis.
I even tried removing the led.
All with no luck.
Any ideas?
All with no luck.
Any ideas?
- induction
Pulldowns on the jacks don't do anything good. They are not connected to the input or output caps when the pedal is bypassed, so they can't bleed charge from the caps to ground, which is what they are for.I have tried a 2m2 resister on the input and output jacks from tip to ground.
It would help if you linked to a specific schematic because there are variations on this circuit, but most of them have a volume pot on the output, so no output pulldown is necessary. Try an input pulldown between the input cap and ground on the board itself.
- induction
The 2M2 resistors that you put between the jack tips and grounds are called pulldown resistors because they are intended to tie the voltage on the input or output caps to ground. When they're left floating, they can take on a non-zero voltage, especially if the caps leak current. Then when you switch the pedal on, the voltage instantaneously switches to zero. That sudden shift in DC voltage is what causes the popping sound.tpruitt wrote:What do you mean by pulldowns?
I'm not intimately familiar with that particular PCB, but if you post a photo of the other side of the board, we might be able to tell you where to put the resistor. A photo of the lug side of the bypass switch would help, too.
- Intripped
just for fun, i've traced again this very famous booster
here is the schematic - the components' numbering matches the PCB's
notes:
i don't understand why the ferrites and 100p caps are always on the signal path, even in fx-bypass; could this be the cause of the POP?
i ask this because i had another EH pedal with issues (bass big muff), and when i opened it i saw that these ferrites were burnt, so i removed them, and the 100p capacitors as well.
notes:
- induction
If Intripped's schematic is accurate for your unit, the circuit already has pulldown resistors on the input and output. You could try measuring the DC offset at the input and output while the circuit is powered. Measure it while engaged and when in bypass. If the readings are significantly greater than 0V, then that's the problem. If not, then it's something else. (Could be the switch itself.)tpruitt wrote:Well?
Questions:
1. You mentioned it pops in the FX loop. Does it pop when it's used inline with the input?
2. Is it the only pedal in the chain, or are there others, even if they are all bypassed?
The only other pedal I know is true bypass is a ts808 clone I built. My first pedal build.
I just tested and yes it pops.
So I went and looked and the loop. Metro instructions claim while checking ground it should be close to 0 ohms.
I'm reading 3 ohms . I moved the ground from the buss wire straight to the chassis and it still reads the same.
I should add that I tried the lpb boost pedal in the loop of a 5153 and it did not pop.
So,I am totally assuming you are correct here.
I know this is a pedal forum but,do you have any ideas?
My voltage for the metro loop is right where it should be at 295. Calls for 285 to 310.
Again,assuming....the voltage is probably coming into the loop sign from the preamp?
- Intripped
i would try and measure again the ground connection(s) of the metro-loop.
to make an accurate measure, check first the ohmic value between the two tips of the tester: just make the tips touch each other and read the value on the tester.
you will probably read 1 or 2 Ohms, this is due to the slight oxidation of the tips and connections with the tester.
subtract this value to the reading on the metro-loop
also, make sure that the bolt used for the metro-loop ground connection is tight
I am editing the original post so ....
On the ground you were correct and I am reading zero.
Now the loop and the voltage coming out is
Off-- zero
On--- it floats around.but while on the vdc 200m. Floats between .8 and 2.8ish millvolts.
I would think that is significant but I really have no idea here.
Off-- zero
