Panther Distortion DI-10 traced  [schematic]
Manfred
Has thanked: 1597 times
Been thanked: 1301 times
Post by Manfred »
The diode of the switching circuit is broken, visible on that shot.
The anode is connected to the JFET gates.
The foot switch switches mechanical between the on-state and off-state.
theehman
Has thanked: 97 times
Been thanked: 102 times
Post by theehman »
Is that the same board used in the LocoBox pedals?
Ron Neely II
fx schematics and repairs
Manfred
Post by Manfred »
theehman wrote:Is that the same board used in the LocoBox pedals?
Yes,it is.
Manfred
Post by Manfred »
The Schematic was faulty, the IC pin lables were wrong and the capacitor to the level pot is 47nF not 47uf.
Here the corrected schematic.
tube-exorcist
Has thanked: 173 times
Been thanked: 67 times
Post by tube-exorcist »
Schematic is still wrong. there is no cap in parallel to the diodes, this cap is after the 27k-resistor near the tone-pot
tube-exorcist
And BTW:
the resistors near the tone control are - according to the picture - 27k and not 47k.
Manfred
Post by Manfred »
tube-exorcist wrote:And BTW:
Thanks again for the hint, you are right.
Manfred
Post by Manfred »
Sorry, one more fault.
The half voltage filter capacitor is 100uF not 10uf.
The half voltage filter capacitor at the Locobox Distortion 10uf.
tube-exorcist
The 47k resistors in the tone control are still wrong. They should be 27k, according to your pictures.
Manfred
Post by Manfred »
tube-exorcist wrote:The 47k resistors in the tone control are still wrong. They should be 27k, according to your pictures.
Thanks a lot for having a closer look at. :thumbsup
Sorry, I must be blind while tracing. :?
I hope got it now.
apollomusicservice
Has thanked: 64 times
Been thanked: 819 times
Post by apollomusicservice »
47pF - first transistor base to ground, drive pot terminal 2 to ground, output transistor 10u to 220k to ground and 1k out, at montage schematic Vref 10u reverse polarity.
Manfred
Post by Manfred »
apollomusicservice wrote:47pF - first transistor base to ground, drive pot terminal 2 to ground, output transistor 10u to 220k to ground and 1k out, at montage schematic Vref 10u reverse polarity.
Thanks a lot for your assistance.
apollomusicservice
missing 1N914 reverse polarity protection diode and negative terminal from DC jack
Manfred
Post by Manfred »
apollomusicservice wrote:missing 1N914 reverse polarity protection diode and negative terminal from DC jack
Thanks again,
Diode is added.
Manfred
Post by Manfred »
Drawing error in the switching control part fixed.
