REDSON OVERDRIVE 12 schematic  [schematic]
Has thanked: 1104 times
Been thanked: 712 times
Post by Manfred »
I traced my REDSON OVERDRIVE 12 unit.
Post by Manfred »
Drawing error in the switching control part fixed.
roseblood11
Has thanked: 344 times
Been thanked: 297 times
Post by roseblood11 »
How does it sound, compared to better known pedals lie tube screamer or OD-1?
Post by Manfred »
roseblood11 wrote:How does it sound, compared to better known pedals lie tube screamer or OD-1?
I had to reassemble it, then I will answer your question.
Lord Ashram
Post by Lord Ashram »
Hi there, and Thanks a lot for layout and schematic, Manfred!!
Two things I would like to ask:
1st- The layout says IC-pin5 4k7 to virtual ground, schematic says 100k. What´s right?
2nd- Between IC-pin 2 and 1 layout says 100k, schematic 10k. Again, what´s right?
Thanks a lot again, great job!
Tobias
Post by Manfred »
Hi Tobias,
thank you for the hint the schematic here the corrected layout:
Ready to print PDF-files:
Redson12OverdrivePCB_ComponentSide.pdf
(20.42 KiB) Downloaded 13 times
Redson12OverdrivePCB_SolderSide.pdf
(12.27 KiB) Downloaded 13 times
SprintLayout 6.0-file:
Redson12Overdrive.zip
(33.4 KiB) Downloaded 12 times
(33.4 KiB) Downloaded 22 times
snk
Has thanked: 64 times
Post by snk »
I love the Redson effects (as well as Rolling, which is the same, i guess), thank you Manfred !
I would be curious to know how it sounds ?
Post by Manfred »
I have been selling the Overdrive for some time but as far as I can remember it was a good sounding mild Overdrive.
Maybe someone else has the original or has built a clone and can tell us more.
