Mooer Tender Octaver guts
apollomusicservice
Has thanked: 64 times
Been thanked: 819 times
Post by apollomusicservice »
Just for info Mooer Tender Octaver.
newly
Post by newly »
it is 3 pcs of pcbs stacked togethers with header pins.
Basically not possible remove each pcb without damaging current component.
Ice-9
Has thanked: 134 times
Been thanked: 359 times
Post by Ice-9 »
newly wrote:it is 3 pcs of pcbs stacked togethers with header pins.
It is easy enough to part the pcb's with either solder braid or a solder sucker, both will do the job :secret: Those little Mooer pedals are quite good value, you get a lot for the cost.
