Diezel VH4 Pedal  [schematic]
grrrunge
Completed builds: Loads!
Has thanked: 50 times
Been thanked: 203 times
Post by grrrunge »
blackboarcult wrote: 28 Nov 2022, 15:13 I did some simulations of this circuit in LTspice and I was actually quite puzzled at the behaviour of the zener diodes in the feedback loop of the 2nd gain stage.
All plots taken just after the gain stage w/5.6V zeners:
- In blue, no diodes.
- In red, D815A diode model.
- In turquoise, BZX384B diode model,
- In green, GP5V6 diode model.
Unfortunately the sims with 1N5232 were giving me a hard time and disproportionate gain amounts.
All diodes present a varying degree of low pass filtering. Earlier in the thread Baja talked about the input signal levels needed for those zeners to conduct being absurdly high and questioning their utility in the circuit, and also mentioned trying them in the third gain stage, getting "muffled"/dark results.
Sorry if it might seem obvious to anybody, but could the zeners be there simply for tone shaping and reducing the highs? or are my sims just misbehaving? :hmmm:
Does anybody have a knowledgeable explanation for this, or for their presence?
The clipping diodes will reduce the gain of the op-amp gain stage to 1 (unity) above the diode threshold voltage, but since this is a large-signal parameter, this is not visible in your AC-simulation. A 6.3V clipping threshold should work fine in a pedal running on 18V :thumbsup
What you see in the AC-simulation, are the variations in small-signal parameters between the different diode configurations. The diodes depletion region introduces capacitance to the PN-junction, and any proper semiconductor model will include some level of parallel resistance to account for leakage currents etc. Hence the differences in gain and bandwidth between the different configurations can be explained by these two factors.
grrrunge
Post by grrrunge »
TBpedals wrote: 13 Jun 2023, 04:30 Help!!!!!! I’m building a PCB Mania Benzin Vh4. I have signal passing however is quiet and has very little gain. Sounds more like a light overdrive. There is a lot of noise and whining specifically when I touch the gain pot with it maxed. I swapped out the pot for a spare I had laying around with the same issue. I have probed the signal and can confirm that it is passing IC1 correctly. It is losing signal strength somewhere before IC2. Any help is greatly appreciated.
https://pcbguitarmania.com/wp-content/u ... B35B8.jpeg
Start by checking your resistor values around R6, R7, R8 and R9. I think the color code of your R9 looks suspicious.
