hi, I've finished my Sansamp GT2 from Tonepad, It works fine, but the Volume knob is too sensitive, is so loud that I can't move it from 8 o'clock. When i turn slightly the knob it turns the volume extremely high which makes it really difficult to adjust the volume.
I wondered if this is normal, has this happened to those who have built it ?, or is there something wrong with mine. If so, how can I fix this?
I'm using IC's NE5532, the pots are 100k Lin., transistor 2N3904
thanks for your help...
http://www.tonepad.com/getFile.asp?id=112
Tonepad Sansamp GT2 Volume knob too sensitive
- Completed builds: TS-808, SansAmp GT-2, ProCo Rat, ZW-44, Rebote Delay 2.5, Boss CE-2, ssm2166 compressor, selfmade EL84 15W tube head with Engl E530 pre, Bogner Sharp - Fender Twin tube stomp preamp. 5W Plexi style SE amp.
- Been thanked: 1 time
It's very simple. Use 100k Log (A taper) potentiometer instead Linear. Thus yours current 8 hours will become 12.master008 wrote:hi, I've finished my Sansamp GT2 from Tonepad, It works fine, but the Volume knob is too sensitive, is so loud that I can't move it from 8 o'clock. When i turn slightly the knob it turns the volume extremely high which makes it really difficult to adjust the volume.
