Rowin Nano Pedals Rebranded as Ammoon & Donner
mavrim
Been thanked: 24 times
Post by mavrim »
I recently started getting into pedals again after not using them for years. Saw Ammoon pedals on eBay for $20 each with shipping from china via epacket. After getting quite a few of these pedals, I began designing the ultimate nano/mini pedalboard to hold them all.
The Ammoon pedals look identical to the Rowin nano series. At first I opened up the rumble pedal because it was not one of my favorites. I just opened up the metal pedal that I bought for a friend that arrived with a low volume problem. I have been very with the sound/quality of the pedals that I purchased. When I opened up the metal pedal, the mini toggle switch fell apart. My guess is that was the cause of low output signal. My own metal pedal sounds fantastic! I had wondered if ammoon were using current Rowin boards or older versions. When I opened the metal pedal, I saw Razor on the PCB. So that at least answered my question. Rowin currently has the razor out, but metal head was also available. Not sure of any difference between the two models?
mavrim
Post by mavrim »
I tried posting photos, but apparently my iPhone photos are over 1mb and will not upload. ??? I doubt these photos are that big of a file on iPhone. On my camera I have the highest resolution set. Kinda time consuming for me to resize all the photos I planned on uploading.
mavrim
Post by mavrim »
Ammoon Rowin Metal Pedal Gut Shot
mavrim
Post by mavrim »
Please fix this forum so larger photos can be uploaded. Each one of my iPhone photos can not be over 1mb in size. Only 1 photo was able to be uploaded. Please fix this limit problem!
mavrim
Post by mavrim »
Ammoon Rumble (Dumble Amp) gut shot
mavrim
Post by mavrim »
I do notice that these pedals do not use 3PDT switches as I had thought they would. Instead, it appears to be a DPDT switch with a mini relay for true bypass switching.
