Emerson EM-Drive first build no signal
lthobbes
Post by lthobbes »
Hello guys!
I had wanted to get into the hobby of figuring out how pedals work since I use them all the time. I decided to start with what seemed like a relatively easy build, and after doing research I found the schematics for Rugeb's modified Em Drive with a tone knob. I tried to put the schematic on veroboard but as it was my first time I am almost sure this is where I went wrong. I hooked the pedal all up as best as I could and when I plugged it in to my board all seemed well. In bypass my signal is fine, and I can play with the other pedals. My problem is when I turn the pedal on... The guitar signal cuts out and my amp buzzes/hums (the volume depends on my volume and gain knob so I think those are plugged in correctly...)
Can anyone help me double check my work? I don't know enough to figure out whats wrong and I have tried multiple things. I looked online and people said that amp buzz is probably a grounding issue.
Other info: I bought my parts from Mouser Electronics. I tried two transistors: 2n5088 and MPSA18. I accidentally cut the legs too short on the C1 capacitor... I just soldered them back on which is why the cap is sideways. I have no idea if this compromises the value but that also might be causing problems? Idk.
Here is the link to the pictures: https://s350.photobucket.com/user/jwalt ... lus%20Tone
Let me know if there is trouble with the link :D
Thanks so much for your help!
- lthobbes (a confused noob)
sliberty
Post by sliberty »
My approach to debugging a pedal that doesn't produce any sound is to use an audio probe to determine where the signal stops flowing. I would start by probing at the input to the board. Then I would probe in front of the transistor. Then I would probe after the transistor, and finally at the output jack. Once you find a spot where there is no signal, you will know that the problem is before that spot in the circuit.
If you don't have, or know what I mean by an audio probe, it is essentially a capacitor connected a chop stick, connected to a working amplifier (I use one of those little portable amps that people use for an MP3 player). Here is a link:
http://www.tdpri.com/threads/how-to-mak ... be.339721/
lthobbes
Post by lthobbes »
Alright thanks! I'll have to test it out as I am going off of the assumption that my veroboard layout is what is not working
