Hey guys. I was wondering if anyone has an Eagle library part for;
-Dual gang 16mm (standard alpha) pot which is board mounted or which the holes aren't offset (like the ones in the MB library)
-a DPDT switch which is board mounted or where the holes are a bit more spaced out than the on in the MB library.
Thanks in advance!
Need two Eagle library components.
- FiveseveN
Might be quicker to edit or make your own from scratch. Here's a tutorial: http://hackaday.com/2016/09/22/making-a ... le-part-1/
FiveseveN wrote:Might be quicker to edit or make your own from scratch. Here's a tutorial: http://hackaday.com/2016/09/22/making-a ... le-part-1/
Interesting. I didn't know you could do this. Nice!
I may just use two regular pots and space them for a dual gang.
The switch is the real pain.
- Jarno
Lovepedal Eternity
Phase 100
Brown source
Fuzz Face
Flipster
Alembic F2B (tube preamp)
Opamp and FET buffers
Tables
Bookshelves
Basses
- Has thanked: 27 times
- Been thanked: 75 times
Dual 16mm pots are in the pot lbr, I believe that's a standard library.
There's also a switch library, but there are several footprints, so you might want to dig a bit.
