Page 2 of 3
Re: PAL Fx JCM 800 Emulator
Posted: 12 Oct 2017, 18:30
by Manfred
Thanks, that looks good.
But there's one thing:
The middle pot wiring looks a little unfamiliar, but a traced the wiring on the shot and drew down the circuit as I had seen.
Maybe there was a wiring error.
Posted: 12 Oct 2017, 21:01
by J0K3RX
Take a closer look.. The wiper/lug 2 of the mid pot is going to the white connector gn2. Lug 3 of the mid pot is going to lug 1 on the bass pot. Lugs 2 and 3 of the bass pot are soldered together and then connecting to lug 1 of the treble pot...
Posted: 12 Oct 2017, 21:03
by J0K3RX
The added tone adjustment trimmer is 10k
Posted: 13 Oct 2017, 00:27
by Manfred
J0K3RX wrote:The added tone adjustment trimmer is 10k
Thanks, I going to revise the layout und the schematic.
Posted: 15 Oct 2017, 23:14
by Manfred
I made test DC-circuits for each stage and alter the trim pot setting until I could read the anoted drain voltages of the PCB shot.
After that i measured the trim pot values.
Here the results:
RD1 = 34 Kiloohms
RD2 = 98 Kiloohms
RD3 = 18 Kiloohms
RD5 = 15 Kiloohms
RD6 = 20 Kiloohms
The measured forward conductanceof the applied J201 = 1.8 Milliamps/Volts.
Posted: 16 Oct 2017, 21:30
by Manfred
The circuit simulation confirmed the measured trim pot values.
I am not entirely satisfied with the outcome.
All except one of the trim pot settings are in the range of a 47 Kiloohms.
The stage with the sources resistor value of 10 Kiloohms needs a trim pot setting of ~100 Kiloohms to achieve the noted drain voltage.
Where do the difference of the setting range of this stage come from?
Either the measured drain voltage is measured incorrectly or another JFET type id used.
Who knows, perhaps a trim pot with a value of 100 Kiloohm or more is installed in the origianl circuit.
Posted: 16 Oct 2017, 21:39
by Manfred
Typos corrections.
Why is EDIT-button sometimes not displayed and therefore the function cannot apply?
Either the drain voltage is measured incorrectly or another JFET type is used.
Who knows, perhaps a trim pot with a value of 100 Kiloohm or more is installed in the original circuit.
Re: PAL Fx JCM 800 Emulator [schematic]
Posted: 18 Oct 2017, 02:51
by Manfred
Revised schematic and layout:
Zipped Sprint-Layout 6 file:
Posted: 20 Oct 2017, 05:26
by Optical
Nice work. Based on this, you could modify the circuit slightly to achieve several other marshall variants such as the Freidman amps
Posted: 20 Oct 2017, 17:39
by roseblood11
It would be great to have a pcb with the option to build many different circuits that are based on Marshall designs.
Maybe uk-electronic.de could sell them?
Posted: 05 Nov 2017, 15:22
by sego91
I just finished similar build of a jcm 800
Using this Schematic I ordered some boards. Looks, and sounds, really the same to the Pal 800.
Posted: 08 Nov 2017, 14:47
by sego91
Posted: 28 Jan 2018, 01:47
by Nefi_fatobene
I saw a video on YouTube about the mod #34 prototype for pal 800. Does anyone know how to modify the jcm emulator for a similar sound? Any suggestions?
Posted: 28 Jan 2018, 15:09
by roseblood11
Is anybody working on a vero board layout?
Posted: 28 Jan 2018, 21:56
by bmxguitarsbmx
I own and have owned several jcm800's. I had the pal800 in for mods, which I declined to do. I don't see it similar to a jcm800. It was very compressed and reminded me of the pod 2.0 jcm800 model. Yes, it is similar. The real amp is less compressed, much less saturated, and has life. Sorry to be harsh, but it may be a let down. So, heads up. The bsiab2 is 100x better.
Posted: 05 Sep 2018, 04:44
by fuzz_germanium
Manfred wrote:Revised schematic and layout:
PAL_JCM800_PCB_ComponentSide_2.pdf
jcm2pcb.zip
Hello the pcb board, what measure does it have? nice design!
Posted: 05 Sep 2018, 22:48
by Manfred
85mm x 40mm.
Posted: 05 Sep 2019, 12:49
by Pedalist666
Would it sound more tube-like with MOSfets?
Posted: 05 Sep 2019, 12:59
by plush
Pedalist666 wrote:Would it sound more tube-like with MOSfets?
Totally not. It may not work at all.
Posted: 05 Sep 2019, 13:48
by Pedalist666
Thank you for the reply.
I am brand new to pedal technology and i read on youtube that mosfets are the way to emulate tube sound using solid state electronics. i guess that info is wrong.
