Germanium (or sillicon) BJT transistors leakage measuring pr
mailoszyarr
Post by mailoszyarr »
I was trying to measuring transistors leakage and HFE by this method: http://www.geofex.com/article_folders/ffselect.htm
I have two problems:
1. first reading of voltage is highest, then voltage on multimeter is lowering. I don't know if first or last (after few minutes) reading is right.
2. Even if I get highest valu of voltege, HFE calculating by this method is a half of HFE that shows my multimeter.
What I am doing wrong?
boby6kiler
Been thanked: 9 times
Post by boby6kiler »
for me it works for pnp but not with npn
plush
Has thanked: 35 times
Been thanked: 160 times
Post by plush »
boby6kiler wrote:for me it works for pnp but not with npn
For npn you simply flip input voltage polarity on both 9v supply and your dmm
mailoszyarr wrote:Hi,
1. 1st reading must be measured without the load (2.2mOhm). 2nd reading is done when the load is applied. Second reading is always higher that the first one
2. it's okay, it means that your transistor has a lot of leakage, it confuses your DMM, because it was made for modern silicon transistors, that don't have leakage compared to old germanium.
