not MY project: dimension p
mistermikev
my favorite amplifier: deville 4x10
Completed builds: -modded big muff (russian) w 6way rotary selecting clipping dioes/emitter lift/true bypass/new pots.
-modded ts8 with diodes, 4558chip, 10k/100ohm resistors
-byoc analog chorus-built a two true bypass loop/order switch
-tube crusher = tube screamer + orange squeezer
-booster
-nurse quacky
etc
Post by mistermikev »
hello,
so... I'm not sure on the ethical aspects of my post so If I transgress I trust I'll be told.
Over at diystompboxes there is a schem that 'cynicalman' created using two pt2399 to make a pseudo-dimension c.
I've wanted to try a dimension c for quite a while and the two layouts I have seen, as far as I know, are not only complicated as heck but perhaps prone to issues (ticking?). With that in mind this schem appeals to me.
I've tried to setup a user over there... but had issues.
I've done a layout based on that schem - and again - the schematic is not my work, but the layout is. I've checked it several times but have not verified. I'm quite green... and maybe a small step away from 'paint by numbers'. I realize this forum is generally not for newbies... but thought I would stand a chance of learning something even if through brutal smack down style comments. so here goes.
link to schem/thread: https://www.diystompboxes.com/smfforum/ ... ic=94435.0
DimensionP_v1.1.pdf
dimension p layout
(66.54 KiB) Downloaded 165 times
I have all the parts on the board populated... so all the real work is done... now I just have to get it working.
