simple buffer/booster
lucas26
Been thanked: 13 times
Post by lucas26 »
hello,
i was looking for a simple buffer/boost and i did this. in spice it looks good, but i don't have my breadboard at this moment and i read somewhere that the switch could make a pop noise... is this schematic ok or do i need some improvement?
edit: i think this post should be in the workbench section. sorry
FiveseveN
Has thanked: 196 times
Been thanked: 106 times
Post by FiveseveN »
It probably would pop since for a few ms the feedback would be floating. Solution is to simply short the pot for buffer mode. I.e. just use a SPST, excluding pin 1 of the depicted switch and connecting the pot at pin 2.
lucas26
Post by lucas26 »
so, in case someone is interested, here's the final schematic and layout. simple buffer, booster and splitter. this is the first pedal in my chain =)
